23851 Discussions
Drivers
Liudvih2000
When entering the game, it gives this error.
Detected Intel driver version 30.0.101.1692 05/18/2022 00:00:00.
The recommended driver version is xxxx. 15.4251 or later. Please update your drivers at http://downloadcenter.intel.com/ before playing the game.
Do you want to try and run the game anyway? There may be stability, performance or visual corruption issues.
Which driver should be installed ?
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
