23492 Discussions
Elden Ring Nightreign on Intel Iris Xe Graphics
SalesDW
When Elden Ring Nightreign was launched, I installed it on my PC (i5-1135G7 Intel Iris Xe Graphics), and I came across the problem that when starting the game, a white screen appeared and closed after a few seconds. I already had the most recent driver installed when I downloaded the game (32.0.101.6795), which even promised support for the game in question, and later that same day I installed the newly released driver (32.0.101.6874 WHQL) in the hope that they would correct the error, something that did not happen. Please fix this ridiculous error intel, even if the video card is not in the game's minimum requirements (GTX 1060 3gb or RX 580) The same previous game, Elden Ring and its expansion Shadow of the Erdtree work completely fine on this video card (Remembering that Elden Ring base and Nightreign have the same video card requirements) so by logic of 1 + 1 Nightreign should also at least open in this configuration, release a fix as soon as possible, it is disrespectful to those who use their integrated cards and were waiting for the game.
RafaelBombinha
up
ArchieD_Intel
Hi SalesDW,
After conducting a thorough investigation, I have verified that the Intel Iris Xe Graphics does not meet the minimum requirements set by the game developer for this particular version.
While some users may have successfully run earlier versions or similar games on this hardware, it appears that the current version utilizes newer rendering features that are either unsupported or unstable on Intel Iris Xe Graphics.
I recommend reporting this issue directly to the game developer, as they are best equipped to assess whether support or a workaround is possible. They may be able to provide further insights or updates regarding compatibility.
With this, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Archie D.
Fansss
Laughed, the only way to get into the game is by uninstalling Intel drivers. You can actually open Elden Ring Nightreign during the process of uninstalling/reinstalling the graphics drivers. Are Intel users being targeted? AMD users don’t seem to have this issue.
PepoIRISXEl29
New Contributor III
They are responding the same thing to any elder ring, the last of part 2 or Spiderman games too. Idk if they ever are going to fix it
rafay19
Hi pepo and others I strongly recommend the driver version 30.0.101.4032 it claims to play games for 30 mins or 60 mins straight lmk how it goes
Nugerah
rafay19
My friend recommended that becuz I wanted to play last of us 2 unfortunately I deleted the game so I want let ya test it lmk also go for the lowest settings possible
PepoIRISXEl29
New Contributor III
Just tried it. 101.4032 does not fix the red and black rendering problem. so useless for now
rafay19
hey yall if anyone wanted to play silent hill 2 remake on decent fps i posted my video on yt https://youtu.be/NU87oXQ9bBo
you should check it out it gives decent fps to play with optimized tweaks if anyone wants to play it tell me i would make a tutorial for that
kerawill
Same issue here on i5‑1135G7 with Intel Iris Xe. Elden Ring: Nightreign shows a white screen and crashes on launch. Tried both drivers 32.0.101.6795 and 32.0.101.6874 WHQL—no luck. Base Elden Ring and Shadow of the Erdtree run fine, so Nightreign should too (same listed requirements).
This feels like a driver bug specific to Iris Xe. Please fix this, Intel. It’s unfair to users who bought the game expecting support based on your driver notes.
Helpful links:
https://community.intel.com/t5/Graphics/Elden-Ring-Nightreign-on-Intel-Iris-Xe-Graphics/m-p/1694454#M142543
