23699 Discussions
Error Help: igfxpers.exe | IccLibDll.dll
I keep getting a igfxpers.exe Bad Image error at Windows 7 startup that says "IccLibDll.dll is either not running or not designed to run on Windows or it contains an error." I get the error at startup every time. Can someoe help me fix this? I am quite surprised to find almost nothing about this via searches on Google, Microsoft.com and Intel search...
Thanks in advance for your help!
Dan
I have the same problem. I found the driver listed in the Intel HD Graphics driver list with no unknown provider, file version, copyright, and not digitally signed. How to fix this?
swalv1
Problem solved in my case as below.
Here is a similar problem I faced with my Dell Inspiron 17r laptop after I had to restart it when a program hanged.
When I booted, I got an error message "persistwndname: igfxpers.exe - bad image" then it said "c:\windows\system32\IccLibDll_x64.dll is either not designed to run on windows or it contains an error......". I found this file was related to Intel display driver. So I rt clicked on "This PC" icon on desktop -> a dialog box opens -> click on device manager on left pane -> click on the small arrow on the right pan displayed near "Display adapters" -> right click on the name of display adapter -> click on update driver software
It took couple of minutes to download the software, my screen blinked once and the display driver got installed without any questions.
I rebooted the my Dell Inspiron 17r laptop and now I no longer get the message.
Hope this helps. Please do post your experience with similar issue.
Amy_C_Intel
Hello all,
sachinwalvekar, thank you for sharing your outcome, let's hope that this could be useful for other users in the community.
Amy.
