23269 Discussions
Installation of win64_154012 causes a DriverPackageInstall error 0x3AFC
TRoid
Could not install beta driver 4326:
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
Does it fail every single time, or only sometimes?
If you can offer a % rate please do.
tried 5x, always same error
Hardware (HW)
Brand and Model of the system.
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
na
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)
na
How much memory [RAM] in the system (see note2 below).
8 GB
Provide any other hardware needed to replicate the issue.
ie: Cables&brand, cable type [vga, hdmi, DP, etc], dock, dongles/adapters, etc
Hardware Stepping (see note1 below).
0A
<img __jive_ID="248734" alt="" class="jive-image image-1" height="351" src="pastedImage_3.png" sty...
Allan_J_Intel1
Have you tested by installing driver manually?
File name: https://downloadcenter.intel.com/downloads/eula/25484/Intel-Graphics-Driver-for-Windows-7-8-1-10-15-40-?httpDown=https://downloadmirror.intel.com/25484/eng/win64_154010.4300.zip win64_154010.4300.zip
Please follow steps same as Windows® 8.1 for manual installation: http://www.intel.com/support/graphics/sb/CS-033916.htm Desktop graphics drivers — How to Manually Install a Driver in Microsoft Windows 8* or Windows 8.1*
Allan.
TRoid
Manual installation from zip file worked, using the device manager. So I could install the latest beta driver 20.19.15.4326.
Tom
Allan_J_Intel1
Excellent, I am glad to hear that manual installation has worked for your computer.
Allan.
