23525 Discussions
Error When Selecting "Maintain Display Scaling" in Intel Graphics Command Center
Vaibhav1
Hey, I’m having trouble with the Intel Graphics Command Center and need some help. I was messing around with the display settings and changed the scaling mode to "Stretched." Now, when I try to switch it back to "Maintain Display Scaling" (which was the original setting), I get an error that says, "An error occurred, something went wrong. Try again later." The other scaling options, like "Center" or "Scale Full Screen," work fine, but none of them solve the issue—my screen still looks blurry. I’ve already tried restarting my PC and reinstalling the Command Center, but the problem persists. Any idea how I can fix this?
I have attached the screenshot showing the details of the graphics card.
LeonWaksman
Check if  Display Resolution  and Scale (System > Display settings) are set to the  "Recommended" value).
Leon
Vaibhav1
Hey,
Yes they are set to recommended value, bit this didn't solve the problem, rather, I found out that the defual Refresh rate was changed, so I again changed it to the original refresh rate and everything was fixed.
Wel, thanks to you too 🙂
