22671 Discussions
Exception occurs when window opens via OpenGL(OpenTK)
MYosh8
Dear sirs,
Please find below issue report.
[Description]
   Exception occurs when window opens via OpenGL(OpenTK) application.
   It occurs always when the graphic driver version is "25.20.100.6323".
   The exception never occured by using the former version.
   We suppose that similar phenomenon shold occures other Apps.
   We hope the issue will be fixed at later version ASAP.
[Steps to reproduce the issue/bug:]
   1. Open the new window via OpenGL(OpenTK).
      We provide the exception log Windows output.
[System information]
   Computer model: LB-A08 (made by Logitec)
   CPU: Core i7 6700TE
   OpenGL version : 4.5
   OpenTK version : 1.0.0.201
   Graphic driver version : (exception occured)25.20.100.6323(Intel HD graphics530)
                            (exception did not occure) 23.20.16.4973 (Intel HD graphics530)
Regards, Yoshizawa.
Wanner_G_Intel
Hello MYosh8, Thank you for joining this Intel Community. For Intel® HD Graphics 530 (Windows® 10), the latest version available is DCH 25.20.100.6519. These new drivers are labeled as Windows DCH graphics drivers and they are not backward compatible with our previous graphics drivers that we are now labeling Legacy. https://downloadcenter.intel.com/download/28515/Intel-Graphics-Driver-for-Windows-10?product=88345 Keep in mind that we recommend using Original Equipment Manufacturer (OEM) drivers available at your system manufacturer's support website only. Note: We supply generic versions of graphics drivers for general purposes. Computer manufacturers can change the features, incorporate customizations, or make other changes to the graphics driver software or software packaging. To avoid potential installation incompatibilities, we recommend that you first check with your computer manufacturer and use the driver software provided. Since you are using the OpenTK (The Open Toolkit), you may also post your question at the Developer Zone. Intel® Developer Zone https://software.intel.com/en-us/er Zone Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation
MYosh8
​Hello WaanerG_Intel,
Thank you for your answering.
I will downgrade the version which can work properly with OpenTK.
