23771 Discussions
Executable file not found
Utsav1
whenever i try to launch valorant from IGCC it shows "executable file for this program cannot be found"
this only happens to me while using the IGCC because at other times the game launches perfectly but when i try to optimize it and run it from IGCC then it does not.
i have attached the ssu file for my laptop as well for your help.
Jean_Intel
Hello Utsav1,
In order to better assist you, please create a report using the Intel Graphics Control Panel:
  • Navigate to the Support tab
  • Select System Diagnostic
  • Click Generate Report
  • Select Save and name the output file.
  • Attached it to your next response
Jean O.
Jean_Intel
Hello Utsav1,
I hope you are doing fine.
Jean O.
Jean_Intel
Hello Utsav1
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
