22765 Discussions
External monitor not detected by UHD 620
dmh
Dear Intel Community,
I am currently facing the problem that, seemingly out of the blue, my laptop has stopped recognizing external monitors. Up until Christmas, on every startup, my monitor was recognized and worked without any issue - starting back up in the new year, there is now no signal.
Laptop: Lenovo Thinkpad X1 Yoga
Graphics card: Intel UHD 620
Monitor: Dell P2719HC
I have installed both available Graphics drivers from [ https://www.intel.com/content/www/us/en/download/776137/intel-7th-10th-gen-processor-graphics-windows.html   ] - version 31.0.101.2121 and version 31.0.101.2125. First un-installing the Device via the Windows "Device Manager", then re-installing the drivers sequentially as clean installs, neither driver version worked.
I know that the cable still transmits data - I am using a USB-C cable that both charges the laptop via the external monitor and transmits the screen image. The charging function still works, the laptop is receiving power from the monitor, but without an image signal.
I have tried several other monitors, both using USB-C and HDMI cables, testing that the cables and other monitors work, without success - the problem seems to be that the laptop is no longer recognizing external monitors at all. I have of course also tried using the display settings "Detect" and "Duplicate"/ "Extend" functions.
Attached the long-form SSU and Graphics Command Reports  ---
Thank you very much for any help or further instructions to get the machine to recognize external monitors again!
David
Jose_Intel
Hello @dmh
Thank you for posting on the Intel️® communities.
We sincerely regret you are experiencing issues with your laptop, we will be more than happy to assist you.
Please answer the following:
·      Are you using an adapter/converter or a straight connection?
·      Have you contacted the system manufacturer?
We noticed that the BIOS is not up to date, please download the file from here: 1.59 (for further instructions, please contact the system manufacturer).
Also, please perform a clean installation of the latest version of the OEM graphics driver: Intel HD Graphics Driver for Windows 11 (Version 21H2 or later), 10 (Version 1709 or later) - ThinkPad X1 Yoga 4th Gen.
Jose B.
dmh
Hi Jose and thank you for your message,
I have installed both of your suggested updates, but the laptop still doesn't detect the monitor.
Attached new versions of the SSU and Graphics Command scans.
I am using a direct HDMI/HDMI cable to connect laptop and monitor.
I have also tried a direct USB-C/USB-C cable, where the charging function via the monitor works fine (so there is a connection), but no graphic signal is detected.
I know that the monitor and cables work from testing with other devices.
I have now installed the latest graphics driver from the Intel website, the latest graphics driver from the Lenovo website, as well as the latest BIOS update from the Lenovo website successfully - as well as the obvious solutions (reboot, force detect in Microsoft System Setting, other cables..)
Still no other monitor detected.
Thank you in advance for any other suggestions!
Best
David
Durmy
Hello DMH,
Thank yo for the detailed write-up. I believe I am facing the exact same situation that you faced a few months back, and I have also tried all of the basic troubleshooting (testing different monitors using different HDMI/USB-C ports, uninstalling re-installing the Intel UHD 620 graphics card, rolling back to older versions). Nothing is working unfortunately.
I use other monitors very frequently for work, and would appreciate any guidance on what you did to solve this
Laptop: Lenovo X1 Yoga 4th gen
Processor: i7 8th gen
Graphics card: Intel Graphics UHD 620
Jose_Intel
Hello dmh
Thank you for following our recommendations.
Please allow us to research about this issue internally. We will post back as soon as we have any update.
Jose B.
Jose_Intel
Hello dmh
Thank you for patiently waiting.
After investigating this case, including the reports, we highly recommend checking with the system manufacturer since there’s nothing wrong with the driver, cables and/or monitor. Please contact Lenovo Technical Support for further investigation.
Please keep in mind that this thread will no longer be monitored by Intel. Thank you for understanding.
Jose B.
boates
Hi @Jose_Intel
I am having the same problem with a Dell laptop. It seems given this is not an isolated issue that this is more likely a driver issue than an issue a manufacturer is likely to help with (as these machines are 7 years old).
My machine knows there is a 2nd screen but I can't set the resolution.
If I try to show only 2nd screen it just reverts immediately to 1st (laptop) screen. I got an error in Windows at one point saying the driver was unable to show on a 2nd screen but that was on the login screen so I didn't get a screenshot.
fernando_mondo
I'm facing the same issue
fernando_mondo
Hi everyone, I'm facing the same issue, and it started happening after the mandatory Windows 11 updates.
I noticed there's nothing wrong with the hardware, as I used a USB boot to run Linux, and the default Linux drivers were enough to project to the external monitor.
However, on Windows 11, I’ve installed all the suggested drivers for the UHD 620 graphics card, but none of them worked to project to the external monitor.
Has anyone found a solution?
dmh
Hi all, my issue did end up resolving itself and the monitor now works fine. I can't tell you what exactly it was that ended up solving the issue. I tried multiple re-installations of the steps described above; new installations of the BIOS system, deleting and re-installing all drivers, and eventually the stars aligned and things went back to working as before. Wish I could be of more help...
