23525 Discussions
Failed RAID 1 Drive
I created a RAID 1 array with 2 identical Seagate Barracuda 21.5 TB drives and then one of the drives failed. This array is not the boot drive. I removed the failed drive and installed a replacement drive (same everything - manufacturer, model, size, etc.) using the same SATA port as the failed drive.
Matrix Storage Console shows:
Arrays
|-Array_0000
|__Volumes
|___RAID-1
|__RAID Hard Drives
|-Port 2:ST31550541AS
|-Missing Hard Drive
Non-RAID Hard Drives
|-Port 0: ST31500541AS
I want to rebuild the array with the existing good drive and hopefully keep all of the data that is on the drive.
I need help rebuilding the array.
Thanks in advance
Dan
