22667 Discusiones
Failed disk replacement for non identical on ICH7r in RAID5
Empleados
2.210 Vistas
oen of my 3 disks in RAID-5 filed. Now I need to replace that disk, but its legacy one Seagate 7200.9. So it cant be replaced for identical disk. Can I add to RAID-5 some other disk without fear of failure whole array?
Thanks for replies,
Vebloud
0 kudos
2 Respuestas
Empleados
805 Vistas
Its likely the disk didn't fail if your using Matrix Storage Manager 8.9
/thread/5036?start=0&tstart=0 http://communities.intel.com/thread/5036?start=0&tstart=0
http://www.intel.com/support/chipsets/imsm/sb/CS-030818.htm http://www.intel.com/support/chipsets/imsm/sb/CS-030818.htm
If so downgrade to 8.8 and mark the drive as normal.
Its not ideal but replacing a drive that's not the same is ok if you can match the following closely:
Make - same
Size – same or bigger
NCQ – same
Cache – same or bigger
RPM - same
Model - any
Empleados
805 Vistas
I try disk in another computer and its failed for sure. Thanks for reply. I will buy new disk as soon as possible.
Responder
