22742 Discussions
Fan speed Metric not showing
Jimmy24
I recently updated my drivers to 32.0.101.6647 update from the previous ones for my pc with intel arc a750 , now it has intel graphics software which used to have fan metric which is not showing , i saw posts of different person , some told that there would be issue with connection of gpu , i ensured my connection but it is not showing so i am assuming that , the feature has been removed in this update can u confirm it please.
Earl_Intel
Hi Jimmy24,
I appreciate you getting in touch with us and spending the time working on the issue you brought up.
To further troubleshoot the issue, try this:
Source link: Can Intel® ARC™ Control Modify the GPU’s Fan Speed in Settings?
Let me know if there will be changes on the issue.
Earl E.
Jimmy24
yes , clean install of drivers did the trick , thanks for the help
JedG_Intel
Hi Jimmy24,
I'm glad to hear that performing a clean installation of the drivers worked. Since the issue is resolved, please advise if we can continue to close this inquiry,
Jed G.
Earl_Intel
Hi Jimmy24,
Earl E.
