22649 Discusiones
Fifa 17 - Display driver stopped responding and has recovered - Iris Pro 5200 graphics - Win 10 64-bit
LLewi2
Principiante
3.014 Vistas
Under heavy graphics use (video game) the screen occasionally freezes for a couple seconds then recovers. A dialog box then appears with the following message:
Display driver intel HD graphics Drivers for Windows 10(r) stopped responding and has successfully recovered
The problem has not (so far) occurred in non-game use.
I have:
- Confirmed Win10 is up to date
- Confirmed the system is running the latest version of DirectX
- Installed the latest graphics driver available on Intel Website (Tried the newest Fifa 17 Beta driver - Beta 15.40.xx.4539 )
- Run memory tests that reported no errors detected
- Added (and removed) registry TdrDelay parameter
Threads here discussing the same error message suggested downloading and installing more recent versions of Intel's graphics drivers than were available on system manufacturers' websites.
Is there a newer generic Intel driver package that might be a solution for this problem? Not sure which other driver to try, tried a few now with the same error even when running the game on the lowest settings, it works for around 10 minutes with no lags and then freezes.
Thanks!
Operating System: Windows 10 Pro 64-bit (10.0, Build 10586) (10586.th2_release.161004-1602)
Language: English (Regional Setting: English)
System Manufacturer: Apple Inc.
System Model: iMac14,1
BIOS: Default System BIOS
Processor: Intel(R) Core(TM) i5-4570R CPU @ 2.70GHz (4 CPUs), ~2.7GHz
Memory: 8192MB RAM
Available OS Memory: 8132MB RAM
Page File: 2800MB used, 7243MB available
Windows Dir: C:\WINDOWS
DirectX Version: 12
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Display Devices
Card name: Intel(R) Iris(TM) Pro Graphics 5200
Manufacturer: Intel Corporation
Chip type: Intel(R) Iris(TM) Graphics Family
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_0D22&SUBSYS_0122106B&REV_08
Display Memory: 4178 MB
Dedicated Memory: 112 MB
Shared Memory: 4066 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: iMac
Monitor Id: APPA012
Native Mode: 1920 x 1080(p) (59.934Hz)
Output Type: Internal
Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igd12umd64.dll,igdumdim32,igd10iumd32,igd10iumd32,igd12umd32
Driver File Version: 10.18.0015.4256 (English)
Driver Version: 10.18.15.4256
DDI Version: 12
Feature Levels: 11.1,11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 2.0
Graphics Preemption: Primitive
Compute Preemption: Thread group
Miracast: Not Supported by WiFi driver
Hybrid Graphics GPU: Integrated
Power P-states: Not Supported
Driver Attributes: Final Retail
Driver Date/Size: 7/17/2015 12:00:00 AM, 36681912 bytes
0 kudos
3 Respuestas
Empleados
1.384 Vistas
Hello Theofingers:
Thank you very much for providing that information.
Based on it, it seems to be that the product that you are using is a iMac14,1, and in that case I just wanted to let you know that Apple has requested that all questions regarding Apple systems and software be addressed directly with Apple support.
I recommend checking the link below for troubleshooting assistance on your Apple computer:
http://www.apple.com/support/imac/intel/ http://www.apple.com/support/imac/intel/
http://www.apple.com/support/mac/n http://www.apple.com/support/mac/n
https://www.apple.com/support/macbook/ https://www.apple.com/support/macbook/
http://www.apple.com/support/macmini/ http://www.apple.com/support/macmini/
Alberto
LLewi2
Principiante
1.384 Vistas
This is not regarding Apple software, I am wanting to know a suitable driver I can use with my graphics card and windows 10.
Empleados
1.384 Vistas
Hello Theofingers:
If you are using an iMac14,1, then even if the graphics controller belongs to Intel, still the support for graphics is provided by Apple, so the best thing to do will be to get in contact with them.
Now, if you are not using an Apple product then:
What is the model of the motherboard?
If it is a laptop, what is the model of the laptop?
Alberto
Responder
