- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
The support techs at 2K have identified the DLL that is crashing the game but have essentially washed their hands of the problem and sent me here. I have a 2nd Generation Intel® Core™ Processor with Intel® HD Graphics 3000/2000 in my laptop. The driver has been uninstalled/reinstalled and is up to date. Still crashing.
Outside of perusing the Game Troubleshooting recommendations, that is the limit of my technical skill. Any help or insight from the community would be greatly appreciated.
Scott
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
For troubleshooting information I recommend following the URL:
http://www.intel.com/support/graphics/sb/cs-010486.htm http://www.intel.com/support/graphics/sb/cs-010486.htm
However, I have checked game requirements for XCOM and it does not mention an on-board graphics solution. Please take a look at the URL below:
http://support.2k.com/entries/22160943-xcom-enemy-unknown-pc-system-requirements http://support.2k.com/entries/22160943-xcom-enemy-unknown-pc-system-requirements
If you are under Windows 7, please test the latest Windows* 8 drivers and let me know if you still have same issue, go here and select Windows 8, either 32 or 64 bit depending on your operating system version and download the driver and test the game.
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Graphics&ProductLine=Desktop+graphics+drivers&ProductProduct=2nd+Generation+Intel%C2%AE+Core%E2%84%A2+Processors+with+Intel%C2%AE+HD+Graphics+3000/2000 http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Graphics&ProductLine=Desktop+graphics+drivers&ProductProduct=2nd+Generation+Intel%C2%AE+Core%E2%84%A2+Processors+with+Intel%C2%AE+HD+Graphics+3000/2000
Allan.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Allan,
I just want to be sure I understand your recommendation. You advise that I load the Windows 8 drivers even though I am using Windows 7, correct? Certainly something I have never done before but is worth trying.
Nic,
1. Laptop.
2. HP Pavilion d7
3. Windows 7, 64 bilt
4. No.
Thank you both for your assistance.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Are you using the drivers provided by your OEM, or the ones off of of our support site?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi nic
I'm having almost the same problem, I tried to look in the area that you had posted and see if maybe i needed to update my drivers as well, but the files that i got after clicking what OS I'm running and all, they both told me my laptop did not use and did not pass the install test it dose at the end, I'm not sure why the game for me crashes after the few logo screens, i don't see any crash reports, I play several big MMOS on this with out a problem such as EvE Online
I have an Acer Aspire, model 7745
My system states that i have these video specs
Name Intel(R) HD Graphics
Adapter Type Intel(R) HD Graphics (Core i3), Intel Corporation compatible
Adapter Description Intel(R) HD Graphics
Adapter RAM 1.71 GB (1,839,456,256 bytes)
Driver Version 8.15.10.2202
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi Troy,
Can you provide for me a copy of your dxdiag? (Start -> Run -> dxdiag -> Save All Information).
-Nic
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
How much of it are you needing, its tons of text in total, are there specific areas you are needing to look at ?
System Information
Time of this report: 11/28/2012, 18:32:20
Machine name: USER-99-PC
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7600) (7600.win7_gdr.120830-0334)
Language: English (Regional Setting: English)
System Manufacturer: Acer
System Model: Aspire 7745
BIOS: PhoenixBIOS 4.0 Release 6.1
Processor: Intel(R) Core(TM) i3 CPU M 370 @ 2.40GHz (4 CPUs), ~2.4GHz
Memory: 4096MB RAM
Available OS Memory: 3764MB RAM
Page File: 2464MB used, 5062MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7600.16385 64bit Unicode
Display Devices
Card name: Intel(R) HD Graphics
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics (Core i3)
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0046&SUBSYS_03681025&REV_18
Display Memory: 1754 MB
Dedicated Memory: 128 MB
Shared Memory: 1626 MB
Current Mode: 1600 x 900 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: CMO1711
Native Mode: 1600 x 900(p) (59.978Hz)
Output Type: Internal
Driver Name: igdumd64.dll,igd10umd64.dll,igdumdx32,igd10umd32
Driver File Version: 8.15.0010.2202 (English)
Driver Version: 8.15.10.2202
DDI Version: 10
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 8/25/2010 12:36:00, 6547968 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4306-11CF-0F7B-6223B8C2C535}
Vendor ID: 0x8086
Device ID: 0x0046
SubSys ID: 0x03681025
Revision ID: 0x0018
Driver Strong Name: oem21.inf:Intel.Mfg.NTamd64:iILKM0:8.15.10.2202:pci\ven_8086&dev_0046&subsys_03681025
Rank Of Driver: 00E60001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_B ModeWMV9_C ModeVC1_B ModeVC1_C
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Thanks for the info Troy. You've got the latest driver for your system according to the Acer support site. You might give our driver a try and see if it fixes the issue, but keep in mind that it's a generic driver and some of your other features may be disabled while using it. http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=21776&lang=eng&OSVersion=Windows%207%20(64-bit)*&DownloadType=Drivers Download Center
Let me know how it goes.
-Nic
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi hurlyburly,
Can you provide some specifics on the system you're using;
1. Is it a desktop or a laptop?
2. Who is the OEM? (Original Equipment Manufacturer; Dell, HP, etc) Or is it home-built?
3. What operating system are you running?
4. Do you have an add-in graphics card in addition to the onboard graphics?
Thank you,
-Nic
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi I have exactly the same problem. Really annoying as you pay the money for a game that should run fine and can barely play it.
HELP!!!!
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hi wezzer237,
Can you post a copy of your dxdiag as well please? (Start -> Run -> dxdiag -> Save All Information) Copy and paste it here and I'll take a look at it.
-Nic
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
