20635 Discussions
Fix open GL 2.0 on windows 10 intel HD 520
PN3
I will install mumu emulator but it need a open GL 2.0 support
How to fix it please?
Thanks 😊
RAJU2529
New Contributor III
If youe have installed latest version , open GL 4.4 is already present in GPU itself , more information visit below site
https://www.intel.com/content/www/us/en/support/products/88355/graphics-drivers/graphics-for-6th-generation-intel-processors/intel-hd-graphics-520.html
But I dont know lower version 2.0 is supported or not .
Other user may clear your doubt
Stefan3D
Sounds like you have no hardware accelerated driver installed, i.e. Microsoft basic display adapter is active.
Make a test with OpenGL Extensions Viewer from http://realtech-vr.com/admin/glview
RAJU2529
New Contributor III
Thanks sir for the link , That application is very useful to me , I downloaded it . Thanks
PN3
Thanks for your respond sir
I saw with your aplication link and I have Open GL 3.0 till 4.5
But maybe my emulator need open GL. 2.0
How to I get it ?
thanks a lot my brother
Stefan3D
I see that the issue also happens with my old Broadwell GPU.
Also on a rig with only NVIDIA GPU.
Seems to be a regression in latest Windows updates and i'm not in the mood to find out when it started...
However OpenGL 2.0 is still there, but you have to enforce the render context.
In OpenGLextensionViewer select renderer from pulldown menu, the entry between generic and forward context 3.0
Go to rendering tests, untick all , select OpenGL 2.0 test and run it
If that works, talk to the developer of "mumu" about the issue.
David_V_Intel
Hello PN3, I am following up with your case and see that we have not heard back from you. Were you able to check the suggestions provided by the users above? If you need more assistance do not hesitate to reply. Regards, David V Intel Customer Support Technician Under Contract to Intel Corporation
David_V_Intel
Hello PN3, I am following up with your case and see that we have not heard back from you. If you need more assistance do not hesitate to reply. Regards, David V Intel Customer Support Technician Under Contract to Intel Corporation
