23801 Discussions
Flashing screen
OGila
i have intel hd grafic 630
I am connected to both a computer screen and a TV screen on an HDMI connection
When I see cables on TV and turn off the TV and then turn back on,
my computer screen pops up, and it stops only when I switch to the computer's HDMI connection to the TV.
Then I can switch to connect the cables back.
Hope my problem has been understood
Hi ofirgilad,
I understand the screen flickers when changing TV to HDMI connection. Let me help you on this matter.
At this point, I would like to get additional information about your system, please run the following utility and attach the results.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- Intel® System Support Utility for Windows*
Also, please confirm if you are using direct HDMI cables like HDMI to HDMI.
Thank you for your time.
Allan J.
Hi ofirgilad,
I need to know if you still need assistance on this matter, I will need the system configuration, please run the https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- Intel® System Support Utility for Windows* and attach results.
Allan J.
