23623 Discussions
Force display resolution without screen (by remote desktop)
AVigo
Hello
On a computer without a display, I would like to know how to change the resolution of the display that is flanged to 1024 * 768.
I have a graphics chipset Mobile Intel 4 series Express Chipset Family
GMA x4500HD
Thanks in advance,
Arnaud Vigouroux.
French :ution ()
Bonjour,
Sur un ordinateur sans écran, je voudrais savoir comment changer la résolution de l'affichage qui est bridé à 1024*768.
J'ai un chipset graphique Mobile Intel 4 series Express Chipset Family
GMA x4500HD
Merci d'avance,
Arnaud Vigouroux.
AVigo
Here the solution of my trouble.
In the bios settings you can set the default size of the screen resolution.
You can select the bigger one there's no limitation.
Then in windows resolution settings you will be able to set the resolution you want for your computer without screen connected...
Bye !
Kevin_M_Intel
Hi ArnoldoV,
Let me help you with this.
It is important to say that the support is provided in English only.
Note that it is possible to change the resolution using either the Intel® Graphics and Media Control Panel or the Windows resolution option but It is necessary to interact with the Operating System to do this change.
AVigo
Hi Kevin,
First great thank you for your reply.
I connect to the computer with a remote desktop (teamviewer). The computer that I need to force the resolution is use like a server. It is in a cabinet with no physical acces, only remote access.
And I need to change screen resolution for a bigger one. The windows resolution settings are bridled (restrained) to 1024*768.
This limitation is not due to the screen because there is no screen connected...
Kevin_M_Intel
I completely understand and thanks for the information. When the system is connected to a monitor it will detect the monitor ID and will display the best resolution according to the monitor specs but when there is no monitor connected to the system it will be using minimum resolution 600x 440.
AVigo
Hello Kevin,
In my case the resolution is blocked to 1024*768 no 600*440.
But it is not very logical to be forced to a minimum resolution.
All server dont have any screen conected on it. However server are not block to a minimal résolution 1024*768.
Does it possible to set up the maximal resolution into the bios setup ?
AVigo
Bye !
