23806 Discussions
Fps dropped after moving.
GDeBe
I recently moved and after hooking up my computer I noticed a significant drop in my fps when playing games. Before it was usually 60fps dropping very slightly when a lot was going on, but now I have frequent drops to 40 fps and sometimes as low as mid 20's. I run an Intel i5 4440 cpu and a Nvidia GEforce 750 ti graphics card. I haven't changed anything since moving and I just can't seem to figure out what the problem is. Any help would be appreciated.
Hello Gdebell,
I understand that after you moved the computer FPS drop while playing games.
Let me apologize for any inconvenience this issue may be causing to you.
In order to help you better I would like to gather more information about the configuration you have in the computer. Please attach to this thread the .txt file the Intel® System Support Utility will generate https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Please let me also know the name of the computer games you are playing in the computer.
To attach a file, you must click "Use Advanced Editor" on the upper right hand corner of the response box, then the "attach" option will appear on the bottom right hand corner of the response box.
Fred D.
Gdebell,
If you need further assistance let us know.
Amy C.
