22867 Discussions
Frame drops and stuttering in Assassin's Creed Syndicate with Intel ARC A750 LE
SparkFrenzy
I am currently running an Intel ARC A750 LE GPU with the driver version 31.0.101.4887 released on 6th October 2023. I am running the game on 1080p and the graphics setting was set to High. To my knowledge, ARC A750 should be well capable of running the game on 60 fps at 1080p and high settings. However, the frame drops below 40 quite often. The frame drops are so frequent that it makes the game almost unplayable. I tried to see if thee frame drops and stuttering persist if I change the graphics settings to low or medium. But doing so only increases the maximum frame rate and doesn't solve the stuttering and frame drops problem. Assassin's Creed Unity is performing better than Syndicate. I can't determine whether this is a game problem or a GPU. problem.
I have attached my system info. Please let me know if there is anything I can do to solve the problem.
