23259 Discussions
G41 express chipset and dual monitors
I am using windows 7 and I have plugged 2 monitors (one is a HP the other Acer) on a video splitter (both VGA) to my computer and the only thing it does is show the same image on both monitors, but I want it to show different ones (extended). When I go to set up the computer to use multiple monitors it doesn't detect the second one. Anyways, could someone please help me with this?
DArce
Valued Contributor III
To be able to get the Multi-monitor configuration on the Intel® Graphics Media Accelerator, you need to use two separate video pipelines which requires two separate video ports. In this case your system would need a VGA port and another VGA, DVI, HDMI, etc. port.
Using a splitter will make the system just to detect one single display so the Multi-monitor configuration options will not work, even though you are seeing an image on both monitors.
