23083 Discussions
GLSL compiler fails to compile valid shader: "cannot evaluate offset into the vector"
Alastair_D_1
The files associated with the bug are here:
https://github.com/mc-imperial/shader-compiler-bugs/tree/master/Intel-HD-Graphics-520-Windows/compile_errors/large-v440-a5f4b3a8898de121_inv_variant_14
System Setup Information:
System Used: Dell XPS
CPU SKU: i7
GPU SKU: HD 520
Processor Line: U-Series
System BIOS Version: Dell Inc. 1.0.0, 10/09/2015
CMOS settings: I can check on request
Graphics Driver Version: 20.19.15.4501
GOP/VBIOS Version: Intel Video BIOS
Operating System: Windows 10
OS Version: Pro
API: OpenGL
Occurs on non-Intel GPUs?: Haven't tried
Steps to Reproduce:
1. Run the Intel GLSL compiler on variant_14_reduced_216_simplified.frag
Expected Results:
The shader should compile successfully.
Actual Results:
ERROR: 0:5: '' : cannot evaluate offset into the vector
Additional Information:
The shader is accepted by glslangValidator.
Michael_C_Intel2
Hi Alastair,
Can you see if the issue reproduces on this new driver?
https://downloadcenter.intel.com/download/26404/Intel-Graphics-Driver-15-45-
-Michael
Alastair_D_1
Hi Michael
Yes, I can still reproduce this issue with the new driver.  Are you able to repro it?
Ally
Michael_C_Intel2
Thanks for checking. I have the ticket filed and will the driver team to investigate.
