23787 Discussions
GLSL link error when using gl_ClipDistance
Olivier_L_
I have the following problem: I write a simple GLSL program with only a vertex shader which writes into gl_ClipDistance:
#version 130
uniform vec4 clipPlane;
out float gl_ClipDistance[1];
void main()
 gl_Position = gl_ModelViewProjectionMatrix * gl_Vertex;
 gl_ClipDistance[0] = dot(gl_ModelViewMatrix * gl_Vertex, clipPlane);
 gl_TexCoord[0] = gl_TextureMatrix[0] * gl_MultiTexCoord0;
 gl_FrontColor = gl_Color;
 gl_BackColor = gl_Color;
It compiles without error, but linkage fails with the error "Out of resource error".
When I remove the line writing to gl_ClipDistance, there is no error any more.
There is also no error if a fragment shader is part of the program.
So the link error only occurs when mixing a programmable vertex shader with the fixed functionality for fragments.
The same error also occurs when using gl_ClipVertex.
Thanks in advance.
Edit:
* Device: Intel HD Graphics 530
* Driver: 21.20.16.4590
Michael_C_Intel2
Is it happening with the latest driver release?
If so then I need the following template filled out so an issue con be properly reported. Also if you have a binary the exhibits this behavior it would be most helpful.
System Setup Information:
System Used: (Manufacturer/Model)
CPU SKU: (i3, i5, Pentium, Celeron, etc.)
GPU SKU: (HD4400, HD5100, etc.)
Processor Line: (Y-Series, U-Series, etc.)
System BIOS Version:
CMOS settings:
Graphics Driver Version:
GOP/VBIOS Version:
Operating System:
OS Version:
API:
Occurs on non-Intel GPUs?:
Steps to Reproduce:
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
Expected Results:
Actual Results:
Additional Information:
