23812 Discussions
GLSL linker crash with sampler2DShadow array
Nicolas_L_1
System Setup Information:
System Used: Microsoft Surface Pro 3
CPU SKU: i5
GPU SKU: HD4400
Processor Line: ?
System BIOS Version: ?
CMOS settings: ?
Graphics Driver Version: 10.18.14.4264
GOP/VBIOS Version: ?
Operating System: Windows
OS Version: 8.1
API: OpenGL
Occurs on non-Intel GPUs?: No
Steps to Reproduce:
1. Compile & link the following vertex & fragment shaders (also can be found here ; https://gist.github.com/nicomgd/08edf6a7741500997414)
shader.frag
#version 150
// UNCOMMENT the following line to crash the linker
// Crash happens on driver 10.18.14.4264 on Windows 8.1 x64, on Intel HD 4400
#define CRASH_DRIVER_PLEASE
in vec4 var_shadowTexCoords;
uniform sampler2DShadow py_shadowMaps[ 1 ];
out vec4 fragColor;
#ifdef CRASH_DRIVER_PLEASE
float _eval_shadow( sampler2DShadow shadowMap, vec4 shadowTexCoord )
  return textureProj( shadowMap, shadowTexCoord );
#else
#define _eval_shadow(a, b) textureProj(a, b)
#endif
void main(void)
    float shadow_factor = _eval_shadow( py_shadowMaps[0], var_shadowTexCoords );
    fragColor = vec4(shadow_factor);
shader.vert
#version 150
out vec4 var_shadowTexCoords;
void init_shadows_es( vec4 someVertex )
  var_shadowTexCoords = someVertex;
in vec4 mg_vertex;
void main(void)
  init_shadows_es(mg_vertex);
  gl_Position = mg_vertex;
Expected Results:
Shaders compile and link.
Actual Results:
Shaders compile, and the call to glLinkProgram crashes the application.
Additional Information:
The code posted above is a stripped down version of a bigger shader.
My understanding is that passing an element of a sampler2DShadow array as an argument to a function causes the crash. If the uniform is changed to become a simple sampler2DShadow value, the crash goes away, idem if the functions are replaced by macros.
FWIW the problem does not occur on the latest avail. driver for HD4000.
Michael_C_Intel2
Thanks for filling out the information. I have will get an internal ticket going and talk to the driver team about it.
-Michael
invisible-cow
I came here to report something very similar. Working on a Blender bug report https://developer.blender.org/T49089. Original reporter is using HD 4600. Below is my system info, after reproducing the crash.
Problem seen when viewing a particular test file. Shaders involved are rather big... generated code from Blender's nodal material system. I'll look for any sampler2DShadow arrays & report back.
System Used: Asus Z87-Plus
CPU SKU: i5-4670K
GPU SKU: HD 4600
System BIOS Version: 2170 PC 14.34 03/07/2013
Graphics Driver Version: 10.18.15.4279 WHQL / Win 10 64
OS Version: 10
API: OpenGL
Occurs on non-Intel GPUs?: no
Expected Results:
glLinkProgram should 1) succeed or 2) fail & report any problems if given bad input.
Actual Results:
Crash inside glLinkProgram. The vertex & fragment shaders compiled successfully with nothing in their info logs.
Tested with a debug context, debug logging enabled. No errors were reported prior to crash.
Shaders are GLSL #version 150  compatibility. Context is GL 4.3 compatibility profile.
Test file exposes a totally different issue on AMD hardware, nothing to do with shader compilation or linking.
