22873 Discussions
GMA 500 SCH US15 Manlow Functional Strap CFG0 - GPU FREQUENCY
kkaza2
Hi, I was reading INTEL sch datasheet (download section) but i don't understand something. There is a little table that show functional strap. What is a functional strap? How can i modify it? I'm interested in CFG0 Control that should manage gfx frequency(from 1 to 0)g. Is it editable by bios(where?acpi?) Or is a hardware setting?
Thank you in advance
DArce
Valued Contributor III
Keep in mind that technical support and information for such products is only available for registered computer manufacturers, vendors, or distributors of Intel products through the Intel® Premier Support Web site.
If you have access to Intel Premier Support, please submit your questions there. If you are unsure if you have access to Intel Premier Support, please contact your Intel sales representative for assistance. Otherwise, request support from your motherboard manufacturer, computer manufacturer, or Intel® Authorized Distributor.
A list of our distributors can be found at the following web site:
http://premierlocator.intel.com/Default.aspx?CountryCPM=PL http://premierlocator.intel.com/Default.aspx?CountryCPM=PL
http://cache-www.intel.com/cd/00/00/08/99/89937_89937.pdf http://cache-www.intel.com/cd/00/00/08/99/89937_89937.pdf
kkaza2
Hi, from my logic if bsel is a functional strap and it is modicable from a jumper also cfg0 should be hardarware.but i'm not sure! Document are in free download section.
So what mean intel with strap? I can't find any document on the web.
I'm not a premier supporter but i think this is a simply question for an intel support forum.
Thabks
DArce
Let me forward your concern in order to see if this information will be available through this channel.
DArce
I have just confirmed and in this case you need to forward your concern through the support channel mentioned above or through the Intel(R) Developer Zone.
To contact Intel(R) Developer Zone, please use the contact information on the following site:
http://software.intel.com/en-us/support Support | Intel® Developer Zone
kkaza2
thank you diego a will move there..goodbye
