23081 Discussions
GMA3600 Windows7 24bit LVDS @100Hz?
We are developing an industrial solution and we use an Intel ATOM N2800 with Windows7. We use a 24bit head mounted display (800x600 dots) which needs a frame rate between 90 and 120Hz. Now it seems, that the GMA 3600 does only support 60Hz @24bit. When you switch to higher frame rates then the GMA3600 only works with 18 bit LVDS.
- Is that true?
- Is there any workaround to use our 24bit LVDS display with GMA3600 @ 90-120 Hz?
BR Roman
Silvia_L_Intel1
Hello BR Roman, thank you very much for contacting us through Intel Communities.
Regarding the GMA3600, we are limited to provide the driver download. If you are experiencing issues or have any additional request it will be necessary to contact the system manufacture.
