23839 Discussions
GPU intel arc b580
RicKing
Cuales opciones de graficos tengo que elegir en mi tarjeta arc 580b para que sea compatible con el juego Alan Wake 2
KentRusselP_Intel
Hi RicKing,
Tenga en cuenta que solo puedo brindar soporte en inglés. He utilizado una herramienta de traducción web para traducir la respuesta; por lo tanto, puede haber algunas traducciones inexactas.
Thank you for reaching out to the Intel Community Forum. I appreciate your message and want to assure you that I’m here to help address your concern. To assist you in determining the most suitable graphics settings for your Intel® Arc™ A580 when playing Alan Wake 2, could you please provide the details below?
Questions:
  • What resolution do you plan to play at (1080p, 1440p, or 4K)?
  • What frame rate are you targeting (30 FPS, 60 FPS, or higher)?
  • What are your CPU and RAM specifications?
  • Do you plan to enable ray tracing features?
  • Have you already tried running the game? If so, what was the outcome?
  • Are you aiming for optimal performance settings, or are you troubleshooting a compatibility issue?
  • Which operating system are you currently using?
Alan Wake 2 – System Requirements:
Recommended Requirements:
  • Graphics Card: GeForce RTX 3060 or Radeon RX 6600 XT
  • Processor: AMD Ryzen™ 7 3700X or Intel® equivalent
  • Memory: 16 GB RAM or higher
  • Operating System: Windows® 10 / 11 (64‑bit)
  • Storage: 90 GB SSD
Minimum Requirements:
  • Graphics Card: GeForce GTX 1070 or Radeon RX 5600 XT
  • Processor: Intel® Core™ i5‑7600K or AMD® equivalent
  • Memory: 16 GB RAM
For your reference, you may check this link: What are the minimum system requirements for Alan Wake 2? - Alan Wake 2 Support
If you have any additional questions or need further assistance, please don’t hesitate to reach out.
Kent Russel P.
KentRusselP_Intel
Hi RicKing,
I just wanted to follow up and check if you’ve had a chance to review the information I shared previously. Your feedback is important, and I’d appreciate it if you could share your thoughts at your earliest convenience.
If you have any questions or need further clarification, please don’t hesitate to reach out.
Kent Russel P.
ChristianA_Intel
Hi RicKing,
I have not heard back from you so I will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitred.
Christian Louierico A.
