23749 Discussions
GPU is limited for every program
zdz00
every program is almost takes 0.2G memory in GPU, the rest is not rendered, i don't know is that a updated problem or a setting problem
AlHill
Describe your problem with more detail.
Download, run, and ATTACH the results of this utility (using the PAPERCLIP under the toolbar):
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then, an Intel support engineer can assist you.
Doc
Esteban_C_Intel
Hello zdz00,
I would like to know if you need further assistance? If so, please provide us with the results of the Intel® System Support Utility for Windows*.
Esteban Ch.
A Contingent Worker at Intel
Esteban_C_Intel
Hello zdz00,
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Esteban Ch.
