23795 Discussions
GPU lockup being seen on Atom E3940 Linux
mdear
I'm cross-posting this question to this forum as well, I'm seeing GPU lockups on an Atom E3940 when running Linux Mint.
I tried to post over a month ago, but apparently got banned even before making my first post, and it took me all this time to get unbanned !?!?
I also have a support ticket open, but it's been several months and still no definitive reply.
excerpt from dmesg log:
[  171.632783] i915 0000:00:02.0: [drm] Resetting rcs0 for preemption time out
[  171.632872] i915 0000:00:02.0: [drm] QSGRenderThread[2286] context reset due to GPU hang
[  171.651466] i915 0000:00:02.0: [drm] GPU HANG: ecode 9:1:859ffffb, in QSGRenderThread [2286]
https://forum.qt.io/topic/152098/qt-dice-example-3d-texture-displays-once-only-on-atom-e3940-linux
Thanks !
Alberto_R_Intel
mdear, Thank you for posting in the Intel® Communities Support.
We will be more than glad to assist you with this matter.
In order for us to provide the most accurate assistance on this scenario, we just wanted to confirm a few details about your system:
Is this a new computer?
Was it working fine before without the GPU lockups that you are describing?
If yes, when did the issue start?
Did you make any recent hardware/software changes that might cause this problem?
Is there any specific application being used when the GPU lockups occur?
https://www.intel.com/content/www/us/en/download/18895/26735/intel-system-support-utility-for-the-linux-operating-system.html
Albert R.
Alberto_R_Intel
Hello mdear, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Albert R.
Alberto_R_Intel
Hello mdear, Since we have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
mdear
I created a new issue https://community.intel.com/t5/Graphics/GPU-lockup-still-being-seen-on-Atom-E3940-Linux-Mint-Victoria/m-p/1559135#M126797  and referred it back to this issue.
In that new issue, I tried to respond to all questions posed by Albert R.
<Myles>
