23550 Discussions
GPUs Supporting Dolby Vision?
Zachicken
Hello!
I've been doing a lot of research in regards to GPUs that support the playback of 4k 60 HDR 10/ Dolby Vision encoding while also being low profile. It's very difficult to find clear support from any source for any brand. I found a one that might fit my needs, but it's unclear weather or not it can support Dolby Vision. The card I have my eye on is the Sparkle Intel Arc A380 ELF, 6GB GDDR6, Single Fan, but it would be amazing if I could get a list of intel cards that are able to encode o and pass through Dolby Vision. Sorry if I'm misrepresenting some terms, I'm a little new to this lol. Thanks in advance!
RandyT_Intel
Hi @Zachicken,
Thank you for posting here in our community. Intel Arc GPUs (including the A380) do support AV1 encoding with enhanced HDR capabilities, which is Intel's modern approach to high-quality HDR content. Intel Arc Cards with Similar CapabilitiesA750,A770 however, you will need to install and setup Dolby Access and Dolby Vision from Microsoft Store and a Monitor or TV and an audio system that support Dolby Vision and Dolby Atmos.
Do Intel® Arc™ A770 and Intel® Arc™ A750 Support Dolby Vision* and...
Let me know if you need more information.
Randy T.
Zachicken
Hello @RandyT_Intel , thank you for your response.
Just to make sure I understand correctly, what you're saying is I'd have to settle on either the A750 or A770 for full support of Dolby Vision and Dolby Atmos? I have all the proper extensions as well as a TV capable of Dolby Vision and Dolby Atmos.
MUC
Honored Contributor I
On PC platforms and PC graphics cards, Dolby Vision is NOT supported for cable transmission in the sense of the Dolby protocol, as known from streaming devices and Ultra HD Blu-ray players.
  • Standard Dolby Vision (DV) – Tone mapping in the display device (RGB 8-bit container).
  • Low-Latency Dolby Vision (LLDV) – Tone mapping at the source based on data reported by the display device and transmitted in a YCbCr 4:2:2 12-bit container.
This is due to licensing reasons.
Further information from practical tests can be found here.
