22663 Discussions
Gigabyte P35x v5 onboard Intel HD 530 HDMI output error/crash
JTähe
Hello there. I have tried finding a similar issue, but haven't found anything, so I thought I'd ask here.
As said in the title, Gigabyte P35x V5 laptop with onboard Intel HD 530 GPU (GeforceGTX 980M as main GPU) is havin issues with HDMI output.
Long story short, everything works fine, as long as no program wants to run in full screen. I cant use to my TV to play a video over HDMI (VLC), even Win10 security screen is triggering the crash. External screen goes black, signal is missing, but the system doesn't switch back to the default screen unless I do it manually.
As I have understood, the HDMI port is physically connected to the Intel GPU. I have tried uninstalling and reinstalling the drivers, updated everything, tried it on other screens, short of reinstalling Windows.
system conf:
Intel® HD Graphics 530
Adapter Compatibility Intel Corporation
Video Processor Intel® HD Graphics Family
Resolution 3840 x 2160
Bits Per Pixel 32
Number of Colors 4294967296
Refresh Rate - Current 59 Hz
Refresh Rate - Maximum 59 Hz
Refresh Rate - Minimum 59 Hz
Driver Provider Intel Corporation
Driver Version 26.20.100.7985
Driver Date 3/9/2020
Adapter DAC Type Internal
Adapter RAM 1.00 GB
Availability Running at full power
Status This device is working properly.
Location PCI bus 0, device 2, function 0
Device Id PCI\VEN_8086&DEV_191B&SUBSYS_C5561458&REV_06\3&11583659&0&10
n_scott_pearson
Where did you get your graphics drivers? Laptops with dual graphics should only be used with the drivers provided by the laptop vendor. Generic drivers from Intel, NVIDA and AMD could cause problems and should not be used without your laptop vendor saying it is ok.
JTähe
Thanks for the tip, will reinstall with manufacturer drivers​
