23093 Discussions
Gma4500 on windows 8.1
ymum
THIS QUESTION IS NOT ANSWERD. I ACCIDENTALY MARKED IT AS ANSWERD.
Would someone kindly help me find a solution for my problem.
Windows 8.1 works with my GMA's windows 7 driver but Ashphalt 8: Airborne road textures and shades do not load.
May someone help.
PS: I uninstalled and went back to vga driver and all the shaders and road textures worked, but with 5fps as there is no proper driver. I have concluded it is the driver that is the problem.
Also the driver supplied through windows update i pathetic to say the least. The reson why i used windows 7 drivers from Intel's site.
Kevin_M_Intel
Hi hp6730b,
I am sorry you are having problems but let me help you.
It is important to say that the chipset you have is a mature product and due to that the latest driver we have for it is for Windows 7. If you are running Windows 8, the best will be to get Windows 7 and install the drivers to have the proper functionality of the graphics controller.
Here you can download the latest driver for your system:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22167 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22167
Kevin M
