23804 Discussions
Graphic Driver for my CPU
KennyG
Hello
Microsoft Support told me to contact here as I do not see my CPU's Graphic in Device Manager.
I am using specs in the screenshot below.
Could any be able to help me find the legitimate source to get the up to date driver?
n_scott_pearson
By default, when an add-in ('discrete') graphics (dGFX) card is installed, the BIOS will automatically disable the processor's internal graphics engine (iGFX). If you wish to use BOTH the iGFX and dGFX engines, you must go into BIOS Setup and configure the iGFX engine to remain enabled regardless of dGFX presence.
Hope this helps,
AlHill
First, your image also does not show your nvidia adapter.  Open it and take another screen shot.
The driver for your processor graphics can be found here:
https://www.intel.com/content/www/us/en/download/785597/intel-arc-iris-xe-graphics-windows.html
Have you updated your bios?  If not, do so.
Have you checked your bios for the proper video settings?  If not, do so.
It may be that insertion of the nvidia card has disabled the processor graphics.  If so, set them properly.  If you cannot, consult with asus.
n_scott_pearson
Hope this helps,
