23851 Discussions
Graphic Driver
Amos_Marcten
is it okay if i update this into my intel iris Xe iGPU?
DeividA_Intel
Hello Amos_Marcten,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with the Intel® Driver & Support Assistant (Intel® DSA).
Before I recommend you not install this driver on your system I would like to investigate this situation further. I will need the following in order to continue:
1. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
2. Provide the logs from Intel® Driver & Support Assistant (Intel® DSA):
Deivid A.
DeividA_Intel
Hello Amos_Marcten,
Deivid A.
