22687 ディスカッション
Graphic problem on Forza Motorsport
Hellbrym
ビギナー
724件の閲覧回数
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
Grapich glitch on the road.
Game: Forza Motorsport.
By the time you’re on track, there seem to be appearing some black grapich flickering on the road.
Hardware (HW)
Brand and Model of the system.
Intel Arc B580
Make and model of any Displays that are used to see the issue (see note2 below).
LFP
= Local Flat Panel (Laptop panel)EFP = External Flat Panel (Monitor you plug in)
LG Full HD Monitor 74,97 Hz
Provide any other hardware needed to replicate the issue.
ie: Cables&brand, cable type [vga, hdmi, DP, etc], dock, dongles/adapters, etc
HDMI
Hardware Stepping (see note1 below).
CPU: Intel i5 12400F
32 GB RAM DDR4
Motherboard: Gigabyte B560M Gaming X DDR4
Software (SW)
SW or Apps version used to replicate the issue.
Intel Driver Version: 32.0.101.6793
Configurations
Single display, clone, or extended (see note2 below).
Single
Display resolution & refresh rate setting of each display (see note2 below).
1920x1080p 74,97 Hz
AC or DC mode, i.e. is power cable plugged in or not?
AC
How to repro
Please provide steps to replicate the issue. These steps are very crucial to finding the root cause and fix.
A screenshot to illustrate the issue is a huge plus. A video of the failure is even better! Attach to the post or provide the YouTube link.
1.Open the game trough the xbox launcher
2. Play the game on ultra settings with ray tracing on or off
3. Laguna Seca and Watking Glen tracks from Builders Cup Practical Performance
4.
n.
5 返答(返信)
RobbieR_Intel
モデレーター
666件の閲覧回数
Hello Hellbrym,
Thank you for reaching out. I understand that you are encountering graphical glitches while playing Forza Horizon with your Intel Arc B580 Card. I appreciate that you have provided a video and it does show square tiles on the road.
To further investigate, please answer the following questions:
  • Was this working fine before?
  • Are you encountering these kind of glitches on other games?
  • Did you make recent changes to the system?
  • Have you tried updating the game it self?
  • What are your game details?
I look forward to your response!
Robbie R.
Hellbrym
ビギナー
630件の閲覧回数
1) First time I've played this game on PC.
2) Only glitches like this I've encountered was on The last of Us Part I (yes, the blue graphic glitch) but it was fixed on driver update. That is one of the reasons that makes me think this is a driver issue.
3) No, my usual setup and software.
4) The game is updated.
5) My game is at ultra with custom high settings RT On. Resolution: 1080p
JeanetteC_Intel
モデレーター
596件の閲覧回数
Hello Hellbrym,
Kindly submit CapFrameX capture data (.json files) reproducing the issue.
  • Capture data at least 3 times to define a good performance baseline.
This will be used for further investigation of the issue.
I look forward to your response soon.
JeanetteC.
Intel Customer Support
JeanetteC_Intel
モデレーター
539件の閲覧回数
Hello Hellbrym,
Let us know if you have any questions.
JeanetteC.
JeanetteC_Intel
モデレーター
490件の閲覧回数
Hello Hellbrym,
Since I haven't received any response from you recently, I will go ahead and close this thread. If you require help in the future, please submit a new inquiry, as this thread will no longer be monitored.
Sincerely,
JeanetteC.
返信
