23086 Discussions
Graphical glitches/artifacts/flickering/mirroring etc with HD 2500 (3470)
Hi there everyone.
I've been dealing with some serious issues with my iGPU in my i5 3470. This all started after my discrete GPU died and I enabled the integrated as a way of using my PC until I could afford a new one. Upon booting up, I found that windows, and games are all affected by different types of graphical artifacts and glitches.
When starting up games, I get flickering reddish dots sprinkled all over the screen. Once I get in, there's portions of the game that are readable, but it's mostly stretched, mirrored and otherwise distorted to the point of being totally unplayable. I'll include some images in my post to more accurately describe the symptoms.
At this point, I'm thinking it could be either ram or cpu damage, a dodgy motherboard, or some weird conflict between these 3 (I've basically removed all devices from my system, and haven't isolated it yet though). I've never seen anything like it before. I have
I've tried heaps of different fixes already, I've run both mint Linux and Windows 7 and both suffer from the same issue. I've updated bios to latest one, updated drivers and windows updates, tried altering video settings, removed a channel of ram, many other things that I can't remember too, and had zero success. I'm at the end of my rope, and thought I should ask the community who are most related to my issue!
My system is as follows:
gigabyte ga-z77-d3h mobo
4gbx2 corsair 1600 vengeance ram
sata2 ssd, sata3 hdd
corsair 620watt psu
custom cooling on the cpu (so heat isn't an issue at all)
dual widescreen samsung monitors (I've tried removing one too, no dice)
Heres the images of the glitches I'm experiencing:http://imgur.com/a/5WphS
Thanks for the input Allan.
I tried installing the driver you linked, no success, the same fault remains.
Hope you've got some intel voodoo up your sleeve to get this thing going properly!
peace
chris
Allan_J_Intel1
Thanks for the information. I will forward this information to the graphics department, in the mean time; can you copy and paste the graphics report? This is generated within graphics control panel.
