22965 Discussions
Help With gl_ext_bindable_uniform on intel hd 4000!!!!!
Hi all
i have problem with Mari on my laptop that have only Intel HD 4000 i just need to practice Mari but when i start Mari 2 i get this error
missing extension gl_ext_bindable_uniform
but other programs like Maya 2013, nuke 7, many games working fine
what can i do to run Mari
i have core i3 4gb ram with Intel HD 4000 OpenGL 4.0 DX11
tanx
DArce
Valued Contributor III
Let me check on this and get back to you with the required information.
thank you for your respond. i am waiting for your information then
DArce
I have confirmed that gl_ext_bindable_uniform extension is not available, however the video controller supports GL_ARB_uniform_buffer_object which is an extension that has evolved from the first one is has more functions. In this case you may need to check that you are using the latest version Mari application (version 2.0v1)
http://www.thefoundry.co.uk/products/mari/ http://www.thefoundry.co.uk/products/mari/
I tried Mari 2.0v1, still asking for that extension.
DArce
When it asks for that extension what happens? Does the application closes and does not run at all, or you just get a message and you may continue using the application?
If you may bypass that message and continue using the application, is there a way you can switch to the supported GL_ARB_uniform_buffer_object method option?
when i start the program it will show me a window that asks for that extension , then i click OK it will close the application.
DArce
Have you checked with the application developer to see if the software can be adjusted to use the GL_ARB_uniform_buffer_object instead?
