23077 Discussions
HW Acceleration with Intel Atom E6xxx series and sDVO
Hello.
I want to see hardware acceleration on intel embeded graphic adaptor E6xxx series on sDVO port. If I get xorg.conf like this http://paste.org.ru/?4joldq http://paste.org.ru/?4joldq vainfo out is:
libva info: VA-API version 0.33.0
libva info: User requested driver 'emgd'
libva info: Trying to open /usr/local/lib/dri/emgd_drv_video.so
libva info: Found init function __vaDriverInit_0_32
Intel(R) Embedded Media and Graphics Driver 1.10 Build 2209
libva error: /usr/local/lib/dri/emgd_drv_video.so init failed
libva info: va_openDriver() returns -1
vaInitialize failed with error code -1 (unknown libva error),exit
Xorg.0.log is http://paste.org.ru/?jj7sfg http://paste.org.ru/?jj7sfg
But if i get clone or extended configuration in xorg.conf - vainfo work good and I do not see video on sDVO port - only light grey rect take place when video must be. There are no problem with LVDS port.
If I run emgdinfo with sDVO connection some error take place:
ERROR while sending INTEL_ESCAPE_VIDEO_CRC_START escape key
ERROR while sending INTEL_ESCAPE_VIDEO_CRC_STOP escape key
ERROR while sending INTEL_ESCAPE_GET_CRC escape key
ERROR while sending INTEL_ESCAPE_GET_CRC_DEBUG_INFO escape key
ERROR while sending INTEL_ESCAPE_GET_PORT_INFO
system information:
Linux 3.2.0-0.bpo.3-686-pae # 1 SMP Thu Aug 23 08:21:41 UTC 2012 i686 GNU/Linux
Debian GNU/Linux 6.0 \n \l
thanks.
DArce
Valued Contributor III
Let me check what would be the proper department to forward this information to and get back to you.
