23492 Discussions
Graphical problems with the game arena breakout
wil822
There are simply black interfaces in the general environment of the game arena breakout infinite, only on the maps, although when you see my components in the Word template you will realize that my hardware is not ideal for this video card, but even so, it is inevitable to want to know what the problem is due to
Earl_Intel
Hi wil822,
I appreciate the effort on providing us the needed information to further investigate on this, I will provide you an update as soon as possible.
While waiting, kindly try to perform Intel Display Driver Uninstaller then try to download the latest version of our Graphics Drivers.
After you perform the DDU,
Kindly run this on your system so that I can also gauge the following peripherals and the driver versions that you have:
Intel® System Support Utility for Windows*
Once finished downloading, open the tool, click on scan (leave the default items checked), click next, then save the system information to a .txt file. Please provide us the .txt file.
Earl E.
Earl_Intel
Hi wil822,
Earl E.
wil822
Hello negative, I was very absent and I have not reviewed your questions sorry to answer until now I managed to come to the conclusion that the problem is in Direx 12, since the problem persisted in other games only if I have run in Direx 12 which is bad since the video game (arena breakout infinite) does not have a section for this
Earl_Intel
Hi wil822,
Thank you for sharing this information with us, I will further check on this and try to replicate it here on our end.
  • May I know where are you playing Arena Blackout Infinite?
  • Can you provide us with the game settings that you're using while playing.
  • May I also know if your and end-user or a developer?
Earl E.
Earl_Intel
Hi wil822,
Earl E.
Earl_Intel
Hi wil822,
Since you have not responded, I will now close this inquiry; this thread will no longer be monitored, so if you require any additional help, please ask a new question.
Earl E.
