23784 Discussions
Graphics 3000 - No Detecta mi TV LED
DAlva6
Hola Tengo una Notebook Positivo BGH i5-2400 placa base con el sistema operativo de 64 bits. Yo solía ser capaz de ver en el cable de hdmi y me reinicia mi pc hoy y ahora ya no detecta dispositivo HDMI (No Conectado).. He instalado los controladores más recientes y aún nada. Ayuda Adjunto Informe: Intel(R) HD Graphics 3000
Report Date: 3/14/2015
Report Time[hh:mm:ss]: 14:49:08
Driver Version: 9.17.10.3347
Operating System: Microsoft Windows 7 Home Premium (6.1.7601)
Default Language: Spanish (Argentina)
DirectX* Version: 11.0
Physical Memory: 3942 MB
Processor: Intel(R) Core(TM) i5-2430M CPU @ 2.40GHz
Processor Speed: 2394 MHz
Vendor ID: 8086
Device ID: 0116
Device Revision: 09
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 3000
Video BIOS: 2102.0
Current Graphics Mode: 1366 by 768
* Devices Connected to the Graphics Accelerator *
Active Notebook Displays: 1
* Built-in Display *
Monitor Name: Monitor PnP genérico
Display Type: Digital
Gamma Value: 2,2
DDC2 Protocol: Supported
Maximum Image Size:
Horizontal: 12,20 inches
Vertical: 06,69 inches
Monitor Supported Modes:
1366 by 768 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Not Supported
Raw EDID:
00 FF FF FF FF FF FF 00 30 E4 E9 02 00 00 00 00
00 14 01 03 80 1F 11 78 0A AA B5 95 58 56 8D 28
1F 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 12 1B 56 72 50 00 0C 30 24 28
35 00 35 AE 10 00 00 19 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 FE 00 4C
47 20 44 69 73 70 6C 61 79 0A 20 20 00 00 00 FE
00 4C 50 31 34 30 57 48 34 2D 54 4C 41 31 00 73
* Other names and brands are the property of their respective owners. *
Kevin_M_Intel
Hola Daniel1964,
Intente instalar el siguiente controlador para su sistema:
https://downloadcenter.intel.com/download/24696/Intel-HD-Graphics-Driver-for-Windows-7-8-8-1-64-bit https://downloadcenter.intel.com/download/24696/Intel-HD-Graphics-Driver-for-Windows-7-8-8-1-64-bit
Si tiene algún problema durante la instalación del controlador, por favor intente los siguientes pasos:
/docs/DOC-22542 https://communities.intel.com/docs/DOC-22542
Otros pasos que puede intentar es probando diferentes tipos de cables. Esto puede ocasionar inconvenientes dependiendo de la calidad del cable.
Kevin M
