23808 Discussions
Graphics Processer Incompatible with Photoshop
McCoole1
I was wondering if someone can give me advice - I keep getting a 'graphics processor is incompatible' when opening Photoshop but when I try and update my Intel(R) HD Graphics 630 I keep getting a "Something went wrong" Exit Code 1. on the Graphic Driver Installer.
Can anyone help or can a direct link to the driver I need?
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[Waiting for Windows 12]
McCoole1
done 🙂
David_G_Intel
Hello McCoole1
Thank you for posting on the Intel️® communities. Please share with us the following information:
  • What driver version are you trying to install?
  • Did you contact Adobe so they can recommend a specific driver version?
  • How do you install the driver?
  • Did you try a clean installation already?
David G
David_G_Intel
David G.
David_G_Intel
David G.
