23586 Discussions
Intel HD Graphics 530 causes permanent black screen on startup?
Magere
Recently my laptop has been having a problem where after I turn it on it shows the logo and then a permanent black screen without moving on to the login screen. The only solution I have been able to find is to start it in safe mode and uninstall the Intel driver which will temporarily work but then Windows 10 will auto-update and reinstall the driver which means the next time I turn it on I have to do this entire process again.
Bastler-42
Hi.
I had much the same problem, try this:
community.intel.com/t5/Graphics/Black-screen-with-Intel-Graphics-Driver-15-40-on-Windows-10/m-p/1246978#M93453
Regards.
Magere
I tried your solution and unfortunately I still have the same problem. Thanks for the attempt though.
David_G_Intel
Hello Magere
Thank you for posting on the Intel️® communities. To investigate, please share the Intel® System Support Utility (Intel® SSU) results:
David G
David_G_Intel
David G.
David_G_Intel
David G.
