23808 Discussions
Graphics driver problem
Sanubose
Hi
I'm using Intel Arc A380 with After Effects + Element 3D.
Scene view shows black objects & handles.
Tried Force Software Rendering, updated drivers, nothing works.
Please confirm OpenGL compatibility & upcoming fix.
AE 2024 | Element 3D v2.2.3
ArchieD_Intel
Hi Sanubose,
  • When did the issue start? Was it after a specific driver update?
  • What are the troubleshooting steps that you tried so far?
  • Is the Resizable Bar enabled?
  • Have you used DDU to completely remove all residual drivers and installed a new one?
  • Have you tried adjusting the graphics settings?
Additionally, to gain a comprehensive understanding of your system, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here. Help Guide for the Intel® System Support Utility.
Archie D.
ArchieD_Intel
Hi Sanubose,
Archie D.
ArchieD_Intel
Hi Sanubose,
Archie D.
Bhaguji
I am looking for a particular driver, and it's driving me mad looking for it,
I have a Windows 10 pro, 8GB, Intel(R) Core(TM) i3-2100 CPU @ 3.10GHz, 3100 MHz, 2 Core(s), 4 Logical Processor(s)
Can somebody please point me in the correct direction and tell/ show me what to do?
The particular driver(s) is: Igdkmd64.sys (published name: oem2.inf). This particular driver is related to the Intel HD Graphics Drivers for Windows(R), I just want a safe way to properly install said driver, can someone please help?
It has to do with the Memory Integrity of my PC - which is at this moment switched off.
I am able to use my PC fine, but just want to sort this issue out, this Driver has been switched off for a few months and now I need it fixed.
I have updated many drivers on my PC and still no fix.
AlHill
@Bhaguji   You need to start your own thread rather than hijacking this one.
[IDSA needs to be abandoned, uninstalled and forgotten]
