I recently upgraded to 8.1 and installed the new HD 4000 drivers.
I have been running 2560x1440 via 55Hz, via HDMI, for a couple of months. Now I can't create the custom resolution in custommodeapp.exe. It gives me the "custom resolution exceeds maximum bandwidth error."
I also noticed that the option to use interlaced instead of progressive is gone in custommodeapp.exe.
Please help. I spent 650 on my dream monitor and it won't work after the update.
Thank you
- 标记:
- Upgrade PC
链接已复制
Please, does anyone know why I can't run my monitor anymore after the new driver update?
Even when I try older drivers, I still get the message "resolution exceeds bandwidth capacity."
It was working fine until the new driver. Is there an old version of custommodeapp.exe that I can use, or something?
Hi bunnyfluffy,
In fact the graphics controller you are using can support up to 2560x1600 resolutions; however, you can get when using Display Port Only. The maximum resolution that you can get with HDMI is 1900x1200. You can check this information at the following link:
http://software.intel.com/en-us/articles/3rd-gen-hd-graphics-quick-reference-guide http://software.intel.com/en-us/articles/3rd-gen-hd-graphics-quick-reference-guide
The latest driver we have for Windows 8.1 can be downloaded at the following link:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23321 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23321
Kevin, Thanks, but that's not true.
I have been running at 2560x1440p, 55hz for a couple months.
Also, the link you posted shows that HD4000 uses HDMI 1.4, which is fully capable. I am getting the error "custom resolution exceeds maximum bandwidth," but that's just not true as there is plenty of bandwidth.
Please advise. Thank you.
Hey Kevin
Same problem here, so i will post my configuration:
Intel(R) HD Graphics 4600
Report Date: 1/21/2014
Report Time[hh:mm:ss]: 14:54:43
Driver Version: 10.18.10.3379
Operating System: Microsoft Windows 8.1 Pro (6.3.9600)
Default Language: English (United States)
Installed DirectX* Version: 11.2
Supported DirectX* Version: 11.0
Shader Version: 5.0
OpenGL* Version: 4.2
OpenCL* Version: 1.1
Physical Memory: 8071 MB
Processor: Intel(R) Core(TM) i7-4700MQ CPU @ 2.40GHz
Processor Speed: 2394 MHz
Vendor ID: 8086
Device ID: 0416
Device Revision: 06
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 4600
GOP Version: 5.0.1032
Current Graphics Mode: 1280 by 800
* Devices Connected to the Graphics Accelerator *
Active Digital Displays: 1
* Digital Display *
Monitor Name: HP LP3065 Wide LCD Monitor
Display Type: Digital
Connector Type: DisplayPort
Serial Number: HWP2690
Gamma: 2.2
DDC2 Protocol: Supported
Device Type: DisplayPort
Maximum Image Size:
Horizontal: 25.20 inches
Vertical: 15.75 inches
Monitor Supported Modes:
1280 by 800 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 22 F0 90 26 01 01 01 01
1D 12 01 03 80 40 28 78 2A 85 85 A8 53 34 AA 25
12 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 BC 1B 00 A0 50 20 17 30 30 20
36 00 81 90 21 00 00 1A BC 1B 00 A0 50 20 17 30
30 20 36 00 81 90 21 00 00 1A 00 00 00 FC 00 48
50 20 4C 50 33 30 36 35 0A 20 20 20 00 00 00 FF
00 43 5A 4E 38 32 39 41 31 56 37 0A 20 20 00 51
* Other names and brands are the property of their respective owners. *
Hey Kevin,
the monitor is a https://www.google.no/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&ved=0CCUQFjAA&url=http://h10032.www1.hp.com/ctg/Manual/c01116432.pdf&ei=DwngUu-HGqT9ywOJiIDACQ&usg=AFQjCNHFh_1-HTrcshCL6a3nGwKkJAbakQ&sig2=2ZN9-nO8gNcCH8Dj7NE4kg&bvm=bv.59568121,d.bGQ HP LP3065 with a resolution 2560 x 1600. So i think it isn't a problem related to the monitor.
Kevin,
Here is the graphics report. Thank you.
Intel(R) HD Graphics 4000
Report Date: 1/22/2014
Report Time[hh:mm:ss]: 12:04:18
Driver Version: 10.18.10.3304
Operating System: Microsoft Windows 8.1(6.3.9600)
Shader Version: 5.0
OpenGL* Version: 4.0
OpenCL* Version: 1.2
Physical Memory: 7813 MB
Processor: Intel(R) Core(TM) i7-3635QM CPU @ 2.40GHz
Processor Speed: 2395 MHz
Vendor ID: 8086
Device ID: 0166
Device Revision: 09
Processor Graphics in Use: Intel(R) HD Graphics 4000
Video BIOS: 0.1
Current Graphics Mode: 2560 by 1440
Active Digital Displays: 2
Non Active Notebook Displays: 1
* Digital Display *
Monitor Name: Dell U2713HM DP
Serial Number: DEL4080
Gamma: 2.2
Maximum Image Size:
Horizontal: 23.62 inches
Vertical: 13.39 inches
640 by 480 (75 Hz)
640 by 480 (60 Hz)
720 by 400 (70 Hz)
800 by 600 (75 Hz)
800 by 600 (60 Hz)
1024 by 768 (75 Hz)
1024 by 768 (60 Hz)
1152 by 864 (75 Hz)
1280 by 1024 (60 Hz)
1280 by 1024 (75 Hz)
1280 by 800 (60 Hz)
1600 by 1200 (60 Hz)
1680 by 1050 (60 Hz)
1920 by 1200 (60 Hz)
2560 by 1440 (60 Hz)
Raw EDID:
00 FF FF FF FF FF FF 00 10 AC 80 40 4C 37 33 31
11 17 01 04 A5 3C 22 78 3A 4B B5 A7 56 4B A3 25
0A 50 54 A5 4B 00 81 00 B3 00 D1 00 71 4F A9 40
81 80 01 01 01 01 56 5E 00 A0 A0 A0 29 50 30 20
35 00 55 50 21 00 00 1A 00 00 00 FF 00 47 4B 30
4B 44 33 34 51 31 33 37 4C 0A 00 00 00 FC 00 44
45 4C 4C 20 55 32 37 31 33 48 4D 0A 00 00 00 FD
00 31 56 1D 71 1E 01 0A 20 20 20 20 20 20 01 FB
02 03 1D F1 50 90 05 04 03 02 07 16 01 06 11 12
15 13 14 1F 20 23 09 7F 07 83 01 00 00 02 3A 80
18 71 38 2D 40 58 2C 25 00 55 50 21 00 00 1E 01
1D 80 18 71 1C 16 20 58 2C 25 00 55 50 21 00 00
9E 01 1D 00 72 51 D0 1E 20 6E 28 55 00 55 50 21
00 00 1E 8C 0A D0 8A 20 E0 2D 10 10 3E 96 00 55
50 21 00 00 18 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5D
* Digital Display 2 *
Monitor Name: Generic PnP Monitor
Connector Type: HDMI
Serial Number: DEL407E
Gamma: 2.2
Device Type: Digital Display
Maximum Image Size:
640 by 480 (75 Hz)
640 by 480 (60 Hz)
720 by 400 (70 Hz)
800 by 600 (75 Hz)
800 by 600 (60 Hz)
1024 by 768 (75 Hz)
1024 by 768 (60 Hz)
1152 by 864 (75 Hz)
1280 by 800 (60 Hz)
1920 by 1080 (60 Hz)
Standby Mode: Supported
Suspend Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 10 AC 7E 40 4C 36 34 37
0A 17 01 03 80 3C 22 78 EA 4B B5 A7 56 4B A3 25
81 80 D1 C0 01 01 56 5E 00 A0 A0 A0 29 50 30 20
4B 44 33 33 37 37 34 36 4C 0A 00 00 00 FC 00 44
00 31 56 1D 71 1C 00 0A 20 20 20 20 20 20 00 FE
* Built-in Display *
Connector Type: LVDS
Serial Number: CMO1720
Gamma: 2.2
Device Type: Built-in Display
Maximum Image Size:
Horizontal: 14.96 inches
Vertical: 08.27 inches
Active Off Mode: Not Supported
Bunnyfluffy,
Just to confirm all the information, this is what is happening to you:
- You were using an older driver and with that driver the resolution 2560 by 1440 (60 Hz) was working fine?
- After the driver update the resolution is not available anymore?
- have tested a different HDMI cable or monitor that support this configuration?
Checking the driver you have it seems it is a different than the 3345. Please download the latest driver provided before and let us know the result.
Correct.
1. I was able to run 2560x1440 @ 60hz HDMI output on the HD4000 prior to upgrading to 8.1
2. After the update to 8.1, I can no longer select the resolution in custommodeapp.exe. I also have noticed that other features have been disabled in custommodeapp (like color depth and interlaced vs progressive)
3. I have tested different cables and I am sure it's not the cable.
Regarding drivers, I have tried all drivers, including 3345. None work with windows 8.1. (They did work with 8.1 preview)
Kevin,
Shader Version: 5.0
Vendor ID: 8086
Device ID: 0166
Device Revision: 09
Video BIOS: 0.1
* Digital Display *
Gamma: 2.2
Maximum Image Size:
640 by 480 (75 Hz)
640 by 480 (60 Hz)
720 by 400 (70 Hz)
800 by 600 (75 Hz)
800 by 600 (60 Hz)
1024 by 768 (75 Hz)
1024 by 768 (60 Hz)
1152 by 864 (75 Hz)
1280 by 800 (60 Hz)
Raw EDID:
Gamma: 2.2
Maximum Image Size:
640 by 480 (75 Hz)
640 by 480 (60 Hz)
720 by 400 (70 Hz)
800 by 600 (75 Hz)
800 by 600 (60 Hz)
1024 by 768 (75 Hz)
1024 by 768 (60 Hz)
1152 by 864 (75 Hz)
1280 by 800 (60 Hz)
Raw EDID:
Gamma: 2.2
Maximum Image Size:
