After updating to windows 8.1 and installing the new intel driver for HD 4000, I can no longer run a custom mode of 2560x1440 at 55hz over hdmi.
This worked fine for months, but now I get the bandwith exceeded error in custommodeapp.exe
Please help, but please don't tell me HDMI 1.4 does not supply enough bandwidth, because I know it does. Not only does it say so in the literature, but I was doing it flawlessly for a long time, until the new drives came out.
Is there another version of custommodeapp.exe that I can use, that won't limit me?
Hi bunnyfluffy,
At this point the only Graphics controller that supports resolution 2560x1440 is the graphics controller included on 4th generation processors. The 3rd generation processors with a HDMI connection can get up to 1920x1200 and it is possible to get the 2560x1440 using Display Port only.
The Custommodeapp.exe, as you know, allows user to create custom resolutions if the requirements are met only.
You can check the information at the following link:
http://software.intel.com/en-us/articles/3rd-gen-hd-graphics-quick-reference-guide http://software.intel.com/en-us/articles/3rd-gen-hd-graphics-quick-reference-guide
On that page you linked to, where does it say that 3rd gen can't output 2560x1440? Please show me, because I've read that page 3 times. That page advertises HDMI 1.4, which DOES have enough bandwidth transmit that resolution.
Again, I was running the monitor happily, until intel put a limit in the software. Maybe the engineers writing the driver mistakenly believed the same thing as you, but it's clear a mistake has been made.
All I'm asking for is for intel to remove the limit in the software on their next driver release. There is no reason to throttle my HDMI bandwidth, especially when the page you linked to advertises HDMI 1.4.
Hi Kevin, I am having the same issue since I upgraded to windows 8.1.
I was happily powering a Catleap Q271 monitor at 2560x1440 over both HDMI and VGA from my Samsung Chronos 7 Laptop with Intel HD4000 gfx + dedicated 8870M radeon Card. I believe it's the HD4000 that is outputting video to the ports?
I had created my custom resolutions in the "Intel Graphics and Media Control Panel" program. This program seems to have been uninstalled during the Win 8.1 upgrade (windows thinks the program is installed but the exe is missing). I am unable to select a custom resolution in the "Intel(R) HD graphics" program.
I used the following settings: http://www.notebookcheck.net/fileadmin/_migrated/pics/2560x1440_intel_hd_graphics_4000_ivy_bridge.png http://www.notebookcheck.net/fileadmin/_migrated/pics/2560x1440_intel_hd_graphics_4000_ivy_bridge.png
I installed Win8.1 tonight and the best it can muster is 1920x1200 over HDMI (i still get 2560x1440 over VGA but it does not look as sharp as I was getting over HDMI)
Please can you talk to your engineers about this since I was viewing my display at 2560x1440, and in fact i was able to run both the VGA and HDMI at the same time from this laptop and both were 2560x1440.
See the enclosed screenshot of VGA set to 2560x1440:
So, as you can see from both image links in this post, people are getting 2560x1440 from these cards over HDMI and VGA, despite what the official specs are saying.
Kevin,
As you can see, this was not a fluke. Many other people have reported the same thing on other sites.
The software is limiting the resolution for no reason. Please, can you help us to remove the limt?
Hi All,
I would like to confirm more information about this. I will need the following:
- Post the dxdiag report here.
- Let me know if you are using a direct connection or video adapters.
- Make sure to install the monitor drivers in the system before posting the dxdiag report.
Hi Kevin, thanks for taking the time to help us on this.
I don't know about bunnyfluffy, but I have solved this issue and I am now viewing this website at 2560x1440 resolution over HDMI. You guys need to give your hardware more credit
I was able to add the custom resolution by following this article:
http://www.intel.com/support/graphics/sb/CS-029478.htm# HDGFX http://www.intel.com/support/graphics/sb/CS-029478.htm# HDGFX
I used the C:\Windows\System32\CustomModeApp.exe utility using the following settings:
Width: 2560
Height: 1440
RefreshRate: 55
Timing Standard: CVT-RB.
and restarted my laptop. The custom resolution was then available by right clicking the desktop and selecting the standard windows resolution menu item.
thanks!
Hi Kevin,
Here is the report:
System Information
Time of this report: 12/6/2013, 21:04:53
Machine name: BunnyFluffy
Operating System: Windows 8.1 64-bit (6.3, Build 9600) (9600.winblue_gdr.130913-2141)
Language: English (Regional Setting: English)
System Manufacturer: SAMSUNG ELECTRONICS CO., LTD.
System Model: 700Z7C
BIOS: P03ABP
Processor: Intel(R) Core(TM) i7-3635QM CPU @ 2.40GHz (8 CPUs), ~2.4GHz
Memory: 8192MB RAM
Available OS Memory: 7814MB RAM
Page File: 4871MB used, 5357MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.03.9600.16384 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 4000
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_0166&SUBSYS_C0CC144D&REV_09
Display Memory: 1792 MB
Dedicated Memory: 32 MB
Shared Memory: 1760 MB
Current Mode: 2560 x 1440 (32 bit) (41Hz)
Monitor Name: Dell U2713HM (Digital)
Monitor Model: DELL U2713HM
Monitor Id: DEL407E
Native Mode: 2560 x 1440(p) (59.951Hz)
Output Type: HDMI
Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32
Driver File Version: 10.18.0010.3304 (English)
Driver Version: 10.18.10.3304
DDI Version: 11
Feature Levels: 11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.3
Graphics Preemption: DMA
Compute Preemption: Thread group
Miracast: Supported
Hybrid Graphics GPU: Integrated
Power P-states: Not Supported
Driver Attributes: Final Retail
Driver Date/Size: 9/9/2013 09:35:44, 12081664 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4226-11CF-A07B-C1E0B4C2C435}
Vendor ID: 0x10DE
Device ID: 0x0FD1
SubSys ID: 0xC0CC144D
Revision ID: 0x00A1
Driver Strong Name: oem46.inf:5f63e5341859ec8c:iIVBM_w81:10.18.10.3304:pci\ven_8086&dev_0166&subsys_c0cc144d
Rank Of Driver: 00DA0001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
DXVA2 Modes: DXVA2_ModeMPEG2_IDCT DXVA2_ModeMPEG2_VLD DXVA2_ModeVC1_VLD DXVA2_ModeVC1_IDCT DXVA2_ModeWMV9_IDCT DXVA2_ModeH264_VLD_NoFGT
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E3...
Hi bunnyfluffy,
It is important to update the drivers in the system. Please try this driver:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23405&lang=eng&OSVersion=Windows%208%2C%2064-bit*&DownloadType=Drivers&OSVersion=Windows%208%2C%2064-bit*&DownloadType=Drivers https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23405&lang=eng&OSVersion=Windows%208%2C%2064-bit*&DownloadType=Drivers&OSVersion=Windows%208%2C%2064-bit*&DownloadType=Drivers
Make sure you uninstall the current driver in your system before installing the one above.
Hi Kevin,
I've uninstalled all other driver installs, down the the generic windows driver, then installed the version you linked to, version 3345.
How should I proceed?
I would like to note that the previous poster and I have the same Samsung Series 7 laptop, and his is working now.
Hi bunnyfluffy,
At this point since you have done all steps provided before, I recommend you testing a different cable in case it is causing this issue or contact the computer manufacturer so you can install their latest driver.
Kevin,
Can you request that the next driver remove the limit? I have tried different cables.
Since this only occurred to everyone after the 8.1 upgrade, it has to be a software problem.
If you think of anything else, please let me know.
Thanks for your help
Hi bunnyfluffy,
I will pass the information to the proper department for future considerations.
![](/skins/images/872293744008A34B36F8ABF94A46CC66/responsive_peak/images/icon_anonymous_message.png)
