22940 Discussions
HD 4000 graphics, Cloned mode are lost when following a link in powerpoint presentation when following a link in powerpoint presentation???
HRøds
My Dell laptop with Intel HD 4000 graphics, are configured with a secondary screen (Vivitek projector and smartboard), in cloned mode. When a link inside a powerpoint presentation are clicked the cloned mode are lost in favour of extended desktop mode!!!!
Has anybody experienced similar problems and come about any solutions?.
Thank you in advance.
Amy_C_Intel
Hello hensemand,
Could you provided us with more information, your computer model, the graphics version you're using, the port that you're using to connect the computer to the secondary screen could you also provided us with the secondary screen model.
Amy.
HRøds
Hi Amy!
Thank you for replying1
Below a complete output from dxdiag. Should contain all inf on computer and graphics.
The porttype is VGA, and the secodary screen is a Vivitek dx881st projektor.
Hensemand
System Information
Time of this report: 9/22/2015, 14:05:27
Machine name: 335-020-131303
Operating System: Windows 7 Enterprise 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.150525-0603)
Language: Danish (Regional Setting: Danish)
System Manufacturer: Dell Inc.
System Model: Latitude E5530 vPro
BIOS: BIOS Date: 08/10/13 19:20:49 Ver: A12.00
Processor: Intel(R) Core(TM) i5-3340M CPU @ 2.70GHz (4 CPUs), ~2.7GHz
Memory: 4096MB RAM
Available OS Memory: 3970MB RAM
Page File: 1404MB used, 6533MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 120 DPI (125 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 4000
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0166&SUBSYS_054A1028&REV_09
Display Memory: 1696 MB
Dedicated Memory: 64 MB
Shared Memory: 1632 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Standard PnP-skærm
Monitor Model: unknown
Monitor Id: CMN15B1
Native Mode: 1920 x 1080(p) (60.006Hz)
Output Type: Internal
Monitor Model: Dx882ST
Monitor Id: DPC7642
Native Mode: 1280 x 800(p) (59.810Hz)
Output Type: HD15
Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32
Driver File Version: 10.18.0010.4226 (English)
Driver Version: 10.18.10.4226
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 5/25/2015 03:19:58, 10948400 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B78E66-4226-11CF-1A63-4025B4C2C735}
Vendor ID: 0x8086
Device ID: 0x0166
SubSys ID: 0x054A1028
Revision ID: 0x0009
Driver Strong Name: oem18.inf:IntelGfx.NTamd64.6.1:iIVBM_w7:10.18.10.4226:pci\ven_8086&dev_0166
Rank Of Driver: 00E62001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY Video...
Amy_C_Intel
Please try the following;
Install the driver http://www.dell.com/support/home/us/en/04/product-support/product/latitude-e5530/drivers/advanced Product Support | Dell US, go to BIOS and chose;
once installed restart your computer.
Then install https://downloadcenter.intel.com/downloads/eula/25313/Intel-HD-Graphics-Driver-for-Windows-7-8-1-10-3rd-Gen-BYT-?httpDown=https://downloadmirror.intel.com/25313/eng/win64_153339.exe win64_153339.exe and once installed restart the computer.
Let me know your findings.
Amy.
HRøds
Hi Amy!
Did the above updates, but it did not change the problem. Cloned mode are stil lost when following a link (to a youtube movie) inside a Powerpoint presentation.
Hensemand
Amy_C_Intel
I performed a lab under these circumstances but I couldn't get the same results at this point let's try the update some components of your system through Windows Update follow these steps http://www.update.microsoft.com/windowsupdate/v6/thanks.aspx?ln=en&&thankspage=5 Microsoft Windows Update.
Amy.
HRøds
Hi Amy!
Windows was already up to date. I tryed whith a HDMI connection, but the problem still remains 😞
Hensemand
HRøds
Hi Amy!
I solved the problem and it had nothing to do with the graphic card or driver.
Powerpoint actually change the screen setup to extended desktop when a slideshow is startet, and do not set it back to cloned mode when you exit the slideshow.
The solution is to enter following in regstry:
[HKEY_CURRENT_USER\Software\Microsoft\Office\15.0\PowerPoint\Options]
"RestoreTopology"=dword:00000001
Hensemand
