*after 30m-1hr of playing.
Driver version: 15.45.12.4552
Hello tvvyydfp,
In regard to your concern, your processor has Intel® HD Graphics 530, please try to do a manual install the latest graphic driver:
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005598.html Uninstalling the Intel® Graphics Driver and Intel® Display HDMI/Audio Driver
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005474.html How to Manually Install a Graphics Driver in Windows 7*
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html Manually Install an Intel® Graphics Driver http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html inhttp://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html Windows® 10 and Windows 8*/8.1*
Latest Graphic Driver: https://downloadcenter.intel.com/download/26404/Intel-Graphics-Driver-15-45-?product=88345 Intel® Graphics Driver [15.45] (Version: 15.45.10.4542 (Latest) Date: 11/9/2016)
If after the installation the issue persists, please reply with the results and the following information: CategoryQuestionsAnswers (N/A if not applicable)DescriptionProvide a detailed description of the issue Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")</span>
Always (100%):
Often (51-99%):
Sporadic (20-50%):
Very Sporadic (<20%):</span>Hardware (HW)Brand and Model of the system. Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too? Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)<td style="width:262px;border-top:none;border-left:none;border-bottom:solid windowt...
Hello tvvyydfp,
I would like to know if the information provided to you was able to solve your concern?
In case if you need further assistance do not hesitate to reply back. CategoryQuestionsAnswers (N/A if not applicable)DescriptionProvide a detailed description of the issue Please place an X to the right of the option showing how often you see this issue using specific steps. (Ex: 'Every few times a game is started it flickers.' <- This would be "Often")</span>
Always (100%):
Often (51-99%):
Sporadic (20-50%):
EFP = External Flat Panel (Monitor you plug in) How much memory [RAM] in the system (see note2 below). Provide any other hardware needed to replicate the issue.
ie: Cables&brand, cable type [vga, hdmi, DP, etc], dock, dongles/adapters, etc Hardwar...
