23106 Discussions
HD 630 GPU seen twice by CLInfo.exe
CGrün
Hi, I am looking into an issue, where the image raw converter Phase One Capture One along with the util CLInfo.exe shows the HD 630 GPU twice.
I have attached the resulting text-file from CLInfo.exe. As a result of this, the software thinks there are 2 cards, distributes its image processing tasks as such, making it very slow performing.
System Setup Information: -----------------------------------------
System Used: MSI GS73VR 7RF Stealth Pro
CPU SKU: I7-7700HQ
GPU SKU: HD630 System
BIOS Version: E17B1IMS.310
CMOS settings: N/A
Graphics Driver Version: 21.20.16.4534
GOP/VBIOS Version: 86.06.18.00.18,6291456
Operating System: Windows 10 Pro
OS Version: Version 10.0.15063 Build 15063
API: N/A Occurs on non-Intel GPUs?: No
Steps to Reproduce: ------------------------------- 1. Run CLInfo.exe util or Phase One Capture One and expect logfiles 2. Observe OpenCL device being detected twice for the HD630
Expected Results: Only 1 instance pr GPU should be found ------------------------------- Actual Results: 2 instances pr GPU found ------------------------------- Additional Information: -------------------------------
Stefan3D
Check the reply in your other topic:
https://communities.intel.com/message/486115#486115
