22989 Discussions
HD630 GPU seen twice by system
CGrün
Hi, I am looking into an issue, where the image raw converter Phase One Capture One along with the util CLInfo.exe shows the HD 630 GPU twice.
I have attached the resulting text-file from CLInfo.exe. As a result of this, the software thinks there are 2 cards, distributes its image processing tasks as such, making it very slow performing.
System Setup Information: -----------------------------------------
System Used: MSI GS73VR 7RF Stealth Pro
CPU SKU: I7-7700HQ
GPU SKU: HD630 System
BIOS Version: E17B1IMS.310
CMOS settings: N/A
Graphics Driver Version: 21.20.16.4534
GOP/VBIOS Version: 86.06.18.00.18,6291456
Operating System: Windows 10 Pro
OS Version: Version 10.0.15063 Build 15063
API: N/A Occurs on non-Intel GPUs?: No
Steps to Reproduce: ------------------------------- 1. Run CLInfo.exe util or Phase One Capture One and expect logfiles 2. Observe OpenCL device being detected twice for the HD630
Expected Results: Only 1 instance pr GPU should be found ------------------------------- Actual Results: 2 instances pr GPU found ------------------------------- Additional Information: -------------------------------
Stefan3D
That's expected behaviour.
One CPU device, one GPU device.
You need to tell your target application which one to use.
Either via command line option or from some menu as seen e.g. in http://www.ozone3d.net/redirect.php?id=401 GPUCapsViewer
If it ain't documented, ask the developer e.g. here:
https://forum.phaseone.com/En/viewtopic.php?f=69&t=26278 Phase One and Leaf-Mamiya Official User to User Forum • View topic - [SOLVED] How to debug GPU acceleration?
