22939 Discussions
HD Graphics 3000 does not switch back to DVI-I after Cable reconnect
MGsch
i am using an HD Graphics 3000 with Windows XP, one Monitor (VGA on DVI-I Adapter) connected.
When i disconnect the monitor an reconnect it again a few seconds later, the screen is black.
I have to press Strg-Alt-F1 to enable the monitor output again. Internal the driver switch to the "Build In Display" and does not recognize that there is the original monitor connected again. I changed the BIOS settings to use only the DVI-I but this does not help.
What can i do to tell the driver that there is one monitor and no " ", even if i disconnect the monitor and reconnect it again?
Manni
DArce
Valued Contributor III
What is the model of the system being used and the video drivers installed?
Furthermore, have you tested using a direct connection between the port and another video display (without using an adapter or converter in between)?
MGsch
This is a Box PC, I'm not sure which type of Mainboard it is. The drivers are up-to-date from the Intel homepage.
I already have an VGA KVM switch, there is no way to use it with DVI. But i will test it tomorrow with an DVI monitor and let you know.
DArce
What would be the manufacturer name and model of the mentioned Box PC? And what is the mentioned up-to-date version of the video driver you have installed? Please provide detailed information on what has been required in order to properly assist you.
Concerning the connection of the TV, we would require you to test with a straight connection with no other device in between (no adapter, converter or KVM)
MGsch
The mainboard is an MI956 Mini ITX from IBASE.The driver version is 6.14.10.5437. But i have seen the same behavior on another system with the same graphics driver.
I connected the PC with an DVI monitor. No adapter, only one normal DVI cable. Then i plugged it off, wait a few seconds and plugged it in again. Same result, the graphic output changes to "Build-In Display" and stays there. The only thing which is different is the HotKey to activate the DVI monitor: Strg-Alt-F4 instead of Strg-Alt-F1.
What I need is only one thing: The graphic adapter has to activate the signal to DVI-I in any case. If there is a cable connected or not (at booting or in operation mode) - the output has to go to the DVI-I.
DArce
Have you tested with the 6.14.10.5321 version that was provided by IBASE on their web site?
http://www.ibase.com.tw/2009/drivers.html IBASE - Drivers List
It is listed as Intel Core i3/i5/i7 Graphics Driver (Win 2K & XP)
Did you try using another operating system such as Microsoft* Windows* 7 or Microsoft* Windows* 8?
In the other hand, I have the feeling that this might be related to how the Video BIOS in the system reacts to that hardware change and having the integrated display as always active, however I have to research and confirm this.
