23851 Discussions
HD Graphics 3000 not detected
MName
Hi, I'm have the i5-2500k and can't use the integrated graphics. It doesn't show up in the Device Manager under Display Adapters and I can't install the drivers because they aren't available for Windows 10. The Intel Processor Identification Utility Software says I'm using the i5-2500k and has "Add-in graphics" under System Graphics. Help would be much appreciated since my GPU is dying and I basically can't watch videos anymore.
Hello, k-dot:
Thank you for contacting the Intel Communities.
In order to get this configured with the iGPU (Processor's graphics) only, it would be required to enable them at BIOS level if available, if not, the way to go is to remove the external GPU from your system so the iGPU can be used.
In regards to the drivers, they are available via windows updates while using Windows 10*, please make sure your system is fully updated.
Some additional informatio you can check regarding this:
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005526.html http://www.intel.com/content/www/us/en/support/graphics-drivers/000005526.html
Esteban C
Hello, k-dot:
Thought I would just check in and find out if you were able to get your iGPU (CPU graphics) to be detected by your system.
I look forward to hearing from you.
Esteban C
