23812 Discussions
HD Graphics 4000 720P resolution wrong Scalling !
Hallo,
i have on some games problem with 1280x720-60HZ scalling.
i saw this problem by my games...
Crysis 1 & Crysis 2 & Crysis warhead - Mafia II - Sniper Elite v2 - Fear 3 and Serious Sam 3 BFE .
with my other games 1280x720 work perfect.
I tested Driver version 2696 and 2761.
I hop Intel fix this problem in next driver version.
Here my System;
Intel i7-3770 - 16GB DDR3 1600MHz - Asus P8Z68-V/GEN3 - SB Recon3D - HDD Raid0 - Asus VS248H.
Windows 7 x64 Ultimate SP1.
Allan_J_Intel1
Hi there!
I appreciate your feedback on this matter. I will make sure your comment reaches the proper department for future consideration.
Thank you for taking the time to communicate this issue to us.
Allan
Hi allan_intel,
thank you for your answer.
I want to say again, with "Max Payne 3" my Intel HD 4000 has 720p resolution Problem to.
If i start the Game, at first i have Display flicker, after i change the resolution to 1280x720-60Hz, it show me wrong display scalling.
Another Problem, with Game "DCS A-10C Warthog" i have Graphic error. If i use External view of my Plan, i see the CAD Graphic
And with the Game "LockOn Flaming Cliffs 2" i have shadow error.
I hop Intel fix this in furure Driver.
MSchm21
Valued Contributor I
What do you mean with wrong scaling? Scaled to full screen, centered etc?
it Scaled to center and smal display
Here Video from LockOn Flaming Cliffs 2 on iGFX 4000,
And here DCS A-10C Warthog on iGFX 4000,
MSchm21
I don't understand your problem. I can switch between centered, full-screen and maintained aspect ratio in the control panel and it all works in 720p for me. You may have to lower your desktop resolution in order to be able to switch between the different scaling options.
i can do that with control panel on the desktop to. but by some games with 1280x720 i have only centred scaling . on the desktop works, by 3d games not work
the video on my post 5, has not scaling problem. they have graphic bug.
MSchm21
ok I haven't tested games, just the Desktop. Maybe it's a different matter for games. Are you sure you switched to 720p on the desktop before starting a game?
yes i changed my desktop resolution to 1280x720 and fixed the display scaling to full size. but if i start Crysis1&2/Mafia2/MaxPayne3 and all games from my Post1, with 1280x720-60Hz, my display scalled to center
btw, with new Intel HD Driver v2791, is that problem not fixed
